Give the Exquisite You Want
The whole deice is smaller than your hand. You can heartily control it with one hand and play it at random.
Give the Fast You Want
Beelink M1 is equipped with New Intel Apollo Lake N3450 processor, which accomplish the balance between performance promotion and low-power consumption.
New generation Inter Apollo Lake N3450 processor achieve the biggest storage---DDR3 8G. It greatly enhance the ability of data analysis and process. Compared to X5-Z8350, it improves and increases 50%.
Give you infinite possibilities to achieve what you want--- M1 is also equipped with 64G ROM, and built-in SSD interface which can support 512G up to the most.
You can easily and deliberately deal with work software, enjoy home theater and play network games.
Give the Clarity You Want
HDMI output interface support 4K full high definition display.
You will never miss every point and every page even every vivid details. We promise that every picture will be smooth to your heart.
Give the Efficiency You Want
More and more tasks, messier and messier desktop, more and more complicated web pages, make your work efficiency lower and lower.
At the time, you only need a VGA.
Don¡¯t worry about multiple windows. You can easily deal with your multiple tasks by VGA. VGA interface brings you the dual screen, which can increase you work efficiency up to the most.
Give the System You Want
Beelink M1 is equipped with Windows 10 Home Edition. More familiar, more user-friendly.
Give the Possibility You Want
Delicate shape with full interface. M1 have everything you expect to find and give you the most possibility.
Three USB 3.0 interfaces support to transfer data, charge, game peripherals etc. It also contains VGA, HDMI interface which support high definition transmission.
No one left behind.
Give the Neatness You Want
Humanity wall-mounting design makes your device find its place.
Brief and fashion wall-mounting design makes your office more neat and ease.
What Do You Still Want
Beelink Give You
Contact me:
[email protected]
