Clone imagine on same boxes
Hi Mo, 60pcs NT-V6 boxes I want to all look the same, I have created my entire setup on the "master" Nagrace NT-V6 box. is there a way to dump that whole box img, apk , FTMC and write it to every box? i really don't want to sit here and install app one by one and configure settings one by oneTags: None
Hi Ahhya 1234 ,
if all Devices have a TWRP Recovery u can make a Backup of the One and install on all others ,
but i think u need root , maybe it can be made with ADB too ??? , but i am not sure and dont have
the Knowledge to explain .
What Rom Version do u use KK/LP/MM or A7 ??? Is your Device rooted ???
I am not sure , but you can make a backup of the Rom with AndroidTool 2.35 ( third Tab ) , and then
flash to all other Devices ?!?!?! (Export Image) function . MAYBE never done , try and report .
good luck
gefattern
Hi Gefattern,
Thanks for your fast reply.
Those boxes already been rooted Rom Version HPH RK3288 Lollipop ROM v1.11 (01-06-2017).
Where can I download AndroidTool 2.3.5 to backup existing Rom with a sample videos clip how to backup and transfer to new boxes.. Thank you a million for reading on my post
Hi Ahhya 1234 ,
first i am not sure if it really works , never tried , look here a Link :
http://ugoos.net/blog/rockchip-firmw...flashing-guide
read this , the Tools are in DL Section .
If the Devices have root u can use TitaniumBackup too , backup all
Apps u want (to SD) or need or even all , then install TB on the new Box
enter SDCard with Backup and restore . (of course u must backup TB too ,
with a AppBackupApp , or always install from Store .
But flashing might be easier . There's for sure another Way , but dont know how .
PS : are u using Mo123 latest Rom for RK3288 from here , or stock Rom
from HPH ???
greetings
gefattern
There are currently 3159 users online. 0 members and 3159 guests.
