Here is coming new generation Beelink BlueLover!
You must can't image its powerful and unique performance.
What is the unique?
1. Run with Ram 8G
You can hold any large-scare office or online games.
2.Support Microsoft Cortana
You can be lazier with Cortana's assistance---you can't lift your finger just need to tell her your demand. She can help you to find files, open music, play a movie etc. as long as you want.
3.Support 2TB HDD and 512G SSD
You will never worry that your PC will be blocked after you have used for a long time. HHD and SSD will give you a enormous space to swallow all of your files, apps, videos and so on.
4.S1 has type-c interface
You guys who have phone with type-c interface are very lucky! Beelink S1 occurs for you.
Following is the specification about S1:
Product: Beelink S1
Dimension: 160*134.5*32mm
Weight: Only Device S1 0.407 KG; With Accessories 0.826 KG
CPU: Intel®Celeron® Quad-core 64bit Processor N3450QC 6W2.2 GHz
Graphics:
Intel® HD Graphics 500 12EUs 700MHz |
HEVC (H.265) 8-bit Decode/Encode |
HEVC (H.265) 10-bit Decode |
H.264 @ Lvl 5.2 Decode/Encode |
JPEG/MJPEG Decode/Encode |
VP8 Decode/Encode |
VP9 Decode |
Latest APIs including DX12, DX11.1 & OpenGL* 4.3 |
Display:
Up to 4K*2KHigh Resolution |
HDMI1.4b up to 3840*2160 |
VGA 1920*1080P |
Memory: DDR3 1600MHz 8GB
Storage:
Onboard 64GB eMMC 5.0 |
Extended M.2 SSD 512GB Storage Card |
Extended Mechanical Hard Disk 2.5inch 2TB |
Network:
Wifi IEEE 802.11 a/b/g/n/ac 2.4G+5.8G |
Lan 1000M |
Bluetooth 4.0 |
USB3.0 | 2* USB Port |
USB2.0 | 2* USB Port |
Type-C | 1* Port |
VGA | 1* Port |
HDMI | 1* HD A Type Port |
RJ45 | 1* RJ45 (1000Mbps) |
Headphone Microphone | 1* Headphone Microphone Jack |
SD Card | 1* SD card Port |
SATA3.0 | 1* SATA3.0 Port |
DC-in | 1* DC in Port |
Support Windows 10/Windows8 |
Support Ubuntu Linux 16.04 |
Support Microsoft Cortana |
Adapter:12V-1.5A 18W
Work Environment:-10°C--45°C, 30%--90% Humidity
Storage Environment:-20°C--60°C, 10%--90% Humidity
Accessories:
1*Adapter 12V 1.5A |
1*HDMI Cable 80MM |
1*HDMI Cable 20MM |
1*Mini PC Holder |
1*Manual |
If you want BlueLover S1, Please buy from this:
If you have any problem, please contact me:
beelinkservice@bee-link.com
