U2C Android 7.1 TV Box Z Super Amlogic S912 Octa Core 3GB RAM 32GB ROM 4K 2017 Update Ultra HD 2.4G 5G Dual-Band Wifi with LED Display Media Player
Get the box set up and turned on. When I go to set up the wifi on the box it freezes up. Rebooting and the box is frozen on the smarttv menu. After turning off the router, and again rebooting it functions normally. This plays out multiple times, with the same result. So I take the unit into the other room and try connecting directly to the router. Unit works perfectly... which is great except I need it in the room where a wired connection isn't possible. Any advice or solutions to this problem would be appreciated... or do I just return the unit and look for other box options?
