This is the upgrade of AP34---AP34 Ultimate
The most salient feature is that AP34 Ultimate is equipped with RAM 8G. And the another additional advantage is the stunning metallic blue appearance.
This is the specification:
Product Model: AP34 Ultimate
Dimension: 119*119*20mm
Processor Number: N3450
Cache: 2MB L2
Instruction Set: 64 bit
OS: Support Windows 10 system
Language: Multi-language
Intel CPU: Intel Processor N3450 2M Cache, up to 2.2GHz
Processor Graphics: Intel HD Graphics 500
Installed RAM: DDR3 8GB
System Disk: Windows(c
Ethernet:1000Mbps LAN
WIFI:IEEE 802.11a/b/g/n/acC2.4G+5.8G
Bluetooth:BT4.0
Antenna:External WiFi antenna
Expand Memory:SD Card (Support 128GB)
# of Cores:4
# of Threads:4
Processor Base Frequency:1.10 GHz
Burst Frequency:2.20 GHz
Scenario Design Power (SDP):4W
Button:1*Power Button
DC-in:1*DC in Port
USB3.0:3* Standard USB3.0 Port
HDMI:1*HDMI Type Port
RJ45:1*RJ45
Headphone microphone:1*Headphone microphone jack
SD Card:1* SD card slot
Power LED:1* power LED
Reset:1* Reset hole(The operating system crashes,
Please do not unplug the power. Press the reset jack, the system will automatically restart)
Power management:AdapterDC12V 1.5A(100-240V,50/60Hz)
Work Environment:5‹C -- 35‹CC30%--90% Humidity
Storage Environment:-20‹C -- 60‹CC10%--90% Humidity
Do you like it?
If you want to buy it, please buy from this:
Please contact me: [email protected]
