Looked on YouTube, did find one with the top off but not how they did it.
How to open a Ugoos ut3s? (4gb)
Hello humptydumpty
To open your UT3S you use a Credit Card or a spatula and go with it on the Sides of the Red Top.
Then you can pop it off.
Neomode
Hi humptydumpty ,
did you get it open ???
maybe this Picture helps :
Bei Abload.de kostenlos Bilder hosten und in Foren, ebay oder anderen Auktionsplattformen usw. nutzen. Die Benutzeroberfläche ermöglicht einfaches bearbeiten deiner Bilder!
not the best Q. of the Pics but you can see how you can do it .
nice Day
gefattern
Got it open. With mobile phone tools. But still damaged (dent it a bit) the plastic on the edge.
Pressing on the edges helped, 0,68 USD of phone tools helped a lot, guitar pick also as a credit card was to thick.
Now I could see the antenna soldering (perfect, smooth and shiny) and measure the ohm (also perfect, 0 ohm on cable and soldering and no short circuit between mantle and antenna).
Thanks for the help.
Hi humptydumpty ,
nice to hear you get it open , if all is good with Antenna , i really can not
understand why your Wifi is so slow .
Did you ever tried one of Mo123 latest RK3288 Roms ??? It can be used
for UT3s too it is a UT3 + Fan , do you have the 2/16 or 4/32 ??? , dont
know if 4/32 works too , asking would help .
have a nice Day
greetings
gefattern
There are currently 1944 users online. 6 members and 1938 guests.
