Hystou FMP05B Core™ i7-6600U 16G/512G 4K Fanless Mini Computer WIFI Gigabit LAN HDMI+DP SATA - Black
    Specification
    Brand Hystou
    Model FMP05b
    Quantity 1 Piece
    Color Black
    Operating System DOS ; Supports Windows XP Windows7 Windows8 Windows10 and all Linux OS
    CPU Core™ i7-6600U 2.6Ghz,Turbo boost 3.4 Ghz
    GPU Intel HD Graphics 520
    RAM DDR3L 16GB
    SSD 512G SSD
    Wifi Connectivity 802.11b/g/n 300MB Wifi with 2 Antennas
    Ethernet Lan: Realtek RTL8168E PCI-E Gigabit Ethernet NIC
    Wan: Half Height Mini PCI-E wifi with 2 antennas
    Bluetooth 3.0
    Video Supported 3GP,AVI,H.264,MP4
    Audio Supported AAC,ACC,MP3,OGG,WAV
    Picture Supported BMP,GIF,JPEG,JPG,PNG
    Office Format Excel,PPT,Word
    E-book Format PDF,TXT
    HDMI Port Yes, Standard HDMI Male 1.4b, support ultra HD 4K resolution
    Other Interfaces SD Card Slot: Yes
    USB Host: 4*USB 3.0+1*USB2.0
    HDMI: Yes, support ultra HD 4K resolution
    DP:Yes
    RJ45 connector: Yes
    DC Jack: Yes
    3.5mm Headphone Jack: Yes
    3.5mm Micphone Jack: Yes
    1*2.5 inch SATA laptop HDD or SDD
    1*mSATA SSD
    Power 12V 3A/5A
    Power adapter Input: 100-240V~50-60Hz
    Output: 12V 3A/5A
    Power consumption TDP 15W
    Others Skype: Supported
    Youtube: Supported
    Speaker: Supported
    MIC: Supported
    Dimension Product size: 35.00 x 24.00 x 1.30 cm / 13.78 x 9.45 x 0.51 inches
    Package size: 43.00 x 31.00 x 13.00 cm / 16.93 x 12.2 x 5.12 inches
    Weight Product weight: 1.350 kg/47.61oz
    Package weight: 1.9 kg/67.02oz
    1 x MINI PC
    1 x Power adapter (A right AC Adapter will be sent as your shipping country)
    1 x Charging cable
    1 x User manual
    Geekbuying
