Zidoo: H6 PRO CortectA53 upto1.8GHz, 2/16GB DDR4, Gig Lan AC WiFI BT4
    Zidoo
    When?
      Now on presale
      Geekbuying
        Must be the replacement for the X6 Pro.
        Pretty but,
          Got this delivered yesterday, have just had time to unbox and connect it and run through the initial setup. Wifi reception seems decent, initial bootup and setup were pretty straightforward, although I did find it curious that the Zidoo "quick settings" menu did not have the option for timezone, you have to navigate to the android settings to change it.
          The included remote is nice, better than most other boxes. The new UI is nice looking, it comes with the Zidoo version of Kodi, which I have not tried yet.
          Will post more detailed impressions tomorrow after I play around with it a bit
            Hi, any update on it? How do you like it?
            What about the 3D graphics on 3D intensive games ? (hardware wise it looks like its weak point)
