cx-919 stock kernels
    here is a link to cx-919 latest stock kernels extracted from stock firmware, to use with any rom at your choice, i use strazoes nexus multiwindows v1.2 and it running great https://www.dropbox.com/sh/lebyv1gzw84dvkd/pw9b0egpOI
    Can you please link me to nexus multiwindow rom?
    And you're using nexus multi window with stock kernel?
    XBMC etc works fine? Does it have the "Internal Memory" Error?
    I know it's alot of question, but thanks.
      here you go http://www.freak-tab.de/strauzo/T428...ows%20v1.2.rar no internel memory error, and using stock kernels works great .....with 1080 kernel you must change build.prop in device/system and set lcd density to 240 instead of 160 else wil icons be too small....i am not using xbmc, because its too buggy yet, and with 1080 i dont think i will be a succes, but if u are using a xaf build it could bee possible.... anyway try for yuor self and feedback its easy to flash different kernels to test,just untick everything else but kernel in included flashtool, you can try first with the system you are running now, to see what effect it does, then you can flash all nexus parts except kernel later
        Thanks a lot for the reply, going to wait for a new finless build. Thanks for the info though, but might try this out.
          is huluplus working?
            cant get Bluetooth to work with both stock kernels and finless kernel with all the nexus roms
