q201-userdebug 6.0.1 MHC19J 20161107 test-keys
MXIII-G II S912 memory 2gb ram 16gb HELP HELP PLEASE!!! ANYONE FIRMWARE
Is there anything in this thread?
http://freaktab.com/forum/tv-player-support/amlogic-based-tv-players/s912/611106-mxiii-g-ii-tv-box-amlogic-s912-octa-core
If you are looking at a firmware that is way better than stock will ever be then I recommend this as one possibility and is the one that I use.
http://freaktab.com/forum/tv-player-support/beelink-aa/beelink-android-tv-box/gt1/firmware-roms-tools-cg/611261-rom-beelink-gt1-alfawise-s92-scv10R-TV BOX S10, Beebox N3150, Chuwi Hibox, Nvidia Shield, A95X Max
Keeping the launcher may be more tricky as despite the fact that the launcher apk can be backed up and essentially installed elsewhere, it is highly unlikely to work as there will be other dependent elements in the firmware that would also be required.
You might also want to make a copy of the remote.conf file that is in/system/etc as if you use the supplied remote then this will be needed in any custom firmware in order to work.
There are currently 2035 users online. 1 members and 2034 guests.
