AllWinner H6 quad-core ARM Cortex-A53 processor up to 1.8GHz
Mali-T720MP2 GPU
2GB DDR4
16GB eMMC flash, micro SD card reader up to 32 GB
1x HDMI 2.0a up to 4K @ 60hz with HDR support, AV port (composite)
H.265/HEVC Main/Main10 profile @ level 5.2 high-tier up to 4Kx2K @60fps, VP9, up to 6Kx3K @ 30fps, H.264/AVC Base/Main/High/High10 profile @ level 4.2; up to 4Kx2K @ 60fps,MKV, MP4, Blu-ray ISO, 3D MVC…, SmartColor 3.0 image optimization engine
HDMI, AV port (stereo audio), optical S/PDIF; DTS and Dolby supported
Gigabit Ethernet, 802.11ac WiFi, Bluetooth 4.1
2x USB 2.0 ports including on OTG port, 1x USB3.0 port on other side. An external power needed if USB connects to over 1TB mobile HDD.
IR receiver, reset/recovery button behind AV port, front panel display (TBC)
5V/2A
Size – 105.6mm x 105.6 mm x 17.5 mm
Bluetooth remote control, HDMI cable, Power adapter, User manual. H6 PRO is currently one of the first, or rather the first TV Box on the market equipped with SoC Allwinner H6,
a big plus for ZIDOO team that sets new trends. At the moment no information on availability.
ZIDOO H6 PRO product page.
