As you can see, the M8S+ original heat sink is held down by cable ties. The original clip was damaged beyond repair and it was one of the reason why my M8S+ had earlier suffer constant reboots as the heat sink was not fully touching the chip.
On idle with the original heat sink, the temperature hovers around 65 degree Celsius.
It goes up to over 90 when running 3D Mark especially during physic test.
..and around 80s running youtube at 720p/60fps.
So I got a hold of an old AMD CPU heat sink lying around and temporary replacing the small heat sink on my M8S+ unit but using the same thermal pad. I didn't even clamp down the heat sink.
The result I got was better than the original heat sink.
Idle temp went down to around 45 degree Celsius
...and reach as high as 65 with 3D Mark
Finally the temperature hovers around 58 with the same youtube video.
Looking at the statistic, it seems the bigger heat sink managed to keep my M8S+ temperature below 70C.
I'm thinking to try out another test using the original tiny heat sink but with fan attached to it although I prefer passive cooling to keep the noise down. Unfortunately passive cooling with this heat sink means my M8S+ will end up looking ugly.
What do you guys think?
