XGody 1/8gb flashed IR remote not working
    I've successfully flashed a the XGody X96 1x8gb box with Firmware from Nexbox (after not being able to find the original XGody Firmware, and my tinkering messed things up).
    It's all working well except that the original remote no longer works with the firmware and F12 does not turn off the box. So pulling the power cable is the only option I can see at the moment. I can send a 'Reboot' command.
    having another stock XGody box (same specs), it there a file I can pull from that one and install into the Nexbox firmware to make the IR Remote work again.
    OR
    Is there a trick to getting F12 or some other key to work on the USB wireless keyboard to power off the box?
    TIA and I was not able to find a post on this so apologies in advance if its right under my nose.
