Pipo M6 4.2.2 RileyROM 1.5 [SDK 2.0] - Download
    The beta firmware I have been getting from this particular site usually only supplies 3G versions, so although it isn't marked as such...I'm assuming this is for the 3G version.
    It will work on a non-3G device, though.
    This ROM is based on Beta #36 firmware dated 8/2/13
    Rooted
    Debloated
    Google Play Store fixes
    init.d support
    2, 4, 6, 8, 10 or 12gb user app space by selecting a parameter file to flash
    Stock Recovery...if you want CWM, get it here:ROM DOWNLOAD
    Please post feedback and comments on this thread:
    Feedback
    If this ROM makes a difference for you, please consider a donation to support future RileyROM's here at Freaktab.com Donate!!!
    Randy
