Many thaks to gearbest for sending the device to work on.
And many thks to trebor for the beta testing
READ THE BUGS SECTION FOR UNNECESSARY QUESTIONS!!!!
Changelog V10:
- NOT BASED ON STOCK!
- Added True 8 core ( All cores now work at 1.5ghz )
- Fixed VP9 Playback
- Added Youtube 4k support.
- On power on the led is purple, and in shutdown mode is off!
- Enabled Multi User support ( Max 3 users )
- Added Dolby Atmos ( See App in all apps, NOT TESTED )
- Added Viper4Android Fx ( See App in all apps, NOT TESTED )
- Added auto hide of the on screen keyboard if you add a airmouse/keyboard ( Some limitations... see bugs )
- Removed Xposed ( Sorry it was messing with some apps not showing in the App store due to the new "SafetyNet exclusion", you guys can flash it if you need it... )
- Netflix is working ( Dont update it if you want it to continue working, i changed the signature of the apk so that like that it wont get auto updated from store )
- Added support Kodi 17 function "Adjust display refresh rate"
- Fixed support HDMI passthrough function in Kodi 17+
- Improved HDMI self-adaptation function ( Settings -> Playback settings )
- Added fractional frequencies for HDMI self-adaptation function
- Added support HLS for HDMI self-adaptation function
- Fixed bug of scaling video
- Added video frames to screenshots
- Added more options to orientation ( Settings -> Device -> Screen orientation )
- Fixed cursor rotation
- Fixed disappearance of the cursor
- Fixed Teamviewer remote control ( works with root, and i do recommend using the fast setting when connecting to it )
- Fixed dark screen bug
- Changed Webview from AOSP to the Google one!
- Added cpu watchdog
- Improved Debug Settings
- Added write permissions for ext4
- Added Xbox360 - Xbox One Gamepads
- Added PS3/PS4 support
- Added kernel module for many USB Bluetooth dongles
- Added Dragonrise USB HID Gamepad driver module
- Added FTMC build 30
- Gapps updated of course!
- More codecs update!
- Red button in the remote brings up the app kill menu!
- Custom Wetek WebOs launcher (Many thks to wetek for let me use it)
- - Menu Button is king on this launcher, its used to add remove icons on the main screen, also to remove widgets.
- - Long press on the default icons on desktop you can change them to other apps (White Logos...)
- - Long press on the icons you add to the deskop and you can rearrange them.
- Gamepad Settings (SC settings -> System -> Gamepad Settings)
- Added choice of actions for sleep timer and power key on RC (Display -> Daydream -> Power key action)
- Added ability of disabling wake up from motions (Display -> Daydream -> Wake up from motion)
- ATV Backdrop added, you can control it in "Settings -> Display -> Daydream." ( you guys need to chose "Backdrop" and add a timer, like 5 min etc... )
- DEFAULT UNROOTED ( to root it simple go to settings and enable it )
- And a lot of other small stuff, and some that i really truly forgot... for real.. i know that i did i just cant remember what.. old age!
- 1º time you boot the box i recommend you guys do a reboot after the initial setup, and setting up the google account!
- Dont try to install Magisk, it wont work!
- You m8 get a small little "quit to launcher" the 1º time you open playstore or do a app install, dont worry it wont do again!
- Mouse pointer sometimes have a double pointer, it should be back to normal after some reboots!
- Suspend mode the led becomes Blue!
- The auto hide of the on screen keyboard may or may not... wrongly identify a only airmouse( the ones without keyboard ) or a cord mouse as a keyboard and m8 not show the on screen keyboard, the only fix is using the remote to show the On Screen Keyboard... sorry!
- CEC disconnecting problems? try using app_fix app (devil face app) and enable the CEC fix, now.. you need to enable root to use that app!
- Miracast only work if the box its connected to a N wifi network(it wont work on AC) and in Miracast setting change to SD resolution, and it should work but sometimes takes some tries.
- Possible more...
- DOWNLOAD HERE SCV1 ROM
- MD5: E7DBC67FE6D3DCE8743ED66D88411CF0
- Use usb burning tool....
- The OTG port for flash is Usb Port2, KEEP THE RESET BUTTON PRESSED A FEW SECONDS (5 to 10) TO DETECT THE BOX.
THIS ROM DELETES ALL YOUR DATA SO DO A BACKUP!
USE AT YOUR OWN RISK!
Enjoy it!
