Again first impression out of the box,
Switch point to a wall looks OK.
Built in battery so had to have a quick look.
Size of a 5in Mobile Phone but twice as thick and not much heavier fit in a pocket pretty easy.
The Spec Mentions
100 lumens mini DLP projector is small size and portable.
The device runs on the Android 5.1, the OS may sound outdated but it is more than enough for a device as a projector. Using the DLP technology to ensure images stable and bright. Digital light processor (DLP) is a general trend in supervising and controlling system.
Main Features:
● Adopt DLP technology to achieve high fidelity image and a clear bright vivid picture
● Support depth customization system, and support office / online video / online games
● Wireless connection with iPhone, iPad, laptop with WiFi, free your hand
● Dual band wireless, 2.4G and 5G ( AC )
● DLP imaging system makes it more economical.
● Keystone correction, trapezoid screen and smart adjustment
● LED light source, energy saving, and low cost
● Built-in 4000mAh lithium-polymer battery, 2 hours of video or power-bank for charging.
A few good features to be had,
Supplied with a small Tripod if required or built in pop up leg.
Carry bag, Remote with Dongle, Instructions 5v 2.5amp Power supply, HDMI cable
Amlogic S905, Android 5.1 2/16GB Ram, AC Wifi and BT
Built in controls also on top of Unit or use remote.
2 x USB-2 ports, TF card and HDMI in
Power and Headphone socket
Keystone correction Top and Bottom and Auto
Resolution 854*480
Display 16.9
Power 3W
States 0.5m 16inch upto 3.0m will give you 120 inch view
Due to the Size and Price Range remember that the expectation is not of a $1000 plus unit,
I do have an old Projector lamp style 1278 max res, this will be an interesting comparison, old one is about 9 or years old Big, Noisey only VGA or Component in only
Like all projectors the darker the room the better.
Lots of ideas come to mind for the use of this, Portable situations, Business displays,
All those times you needed a monitor to show something.
Just a flat surface and you're ready to go,
About 2 hours battery life they state
A few Pictures of the units and then I can have a fiddle for a few days
The Box and What's in it
Ports, Power in On/Off Switch
Manual Focus adjusting and TF card Slot
Lense and Ventilation
Earphone Jack
Underneath small fan inside not to noisey, speaker underneath bit scratchy sound wise, usable.
Just a very Quick look straight up at the Ceiling about 2 mtrs from projector
Light ON
Light OFF
A few Snaps UI from Device and Projector settings the rest is Android no other features
Gearbest
More soon
