http://freaktab.com/forum/tv-player-...l-android-ddr4
Ok so Ive seen alot of posts in the h96 section asking about new firmware and because this firmware is in the Beelink section. Plus because of all the fixes made by super celeron for this device i just had to throw up a demo and some photos and explain why if your using this device you should be using this firmware or his ATV Firmware if thats your flavor prefered.
First off if you look at the change logs of what hes fixed kinda says it all. The wifi works like a dream photo quality and video quality is dreamie to say the least. and everything just works. Yup some minor bugs but wow fixes out way anything not included.
heres some screens of the launcher and tests Ive loaded this box with a massive amount of APKS and its not lagging in any way. Heat issues GONE. WIFI studders GONE so I think Super Celeron has to get The God Rom Dev status soon. or at the least be elevated from Celeron status to a higher CPU
On with the Screens
