Vasteyu V9 S912 TV Box Android 7, 3/32 Dual WiFi BT.
    Click image for larger version  Name:	1501657060938494.jpg Views:	1 Size:	94.4 KB ID:	660971
    Vasteyu V9 S912 TV Box Octa-core H.265 4K Player
    It is the best choice for you to have the smooth experience to watch the video or play games, for it is equipped with Amlogic S912 Octa-core 64bit ARM Cortex-A53 CPU. 2GB / 3GB RAM DDR3 and 8GB / 32GB ROM eMMC, play your favorite Android games on the big screen! Do not worry about memory capacity is not enough. 4K 1080P resolution is 4 times of full HD, so every detail of the screen is lucidity, enables you to feel the most high-definition video.
    Main Features:
    ● Powerful chipsets. Amlogic S912 Octa-core 64bit ARM Cortex-A53 up to 2GHz, ARM Mali-820MP3 GPU processor up to 750MHz.
    ● Its high machine configuration gives you ultra-fast running speed and professional image processing ability.
    ● The appearance of high-grade acrylic, large vents, long runs, fast and stable.
    ● 3 USB interfaces to meet the needs of different users.
    ● Support HDMI / AV OUT variety of video output, to meet different customer needs of different TV.
    ● Support 4K x 2K H.264 / H.265 60fps HDMI 2.0, 4K ultimate HD video hardware, 4K 1080P resolution is 4 times of full HD, so every detail of the screen is lucidity.
    ● The smallest Android TV Box ever. easily to be held in your palm and saved much space for your TV bench.
    ● The remote control is powered by 2 x AAA batteries ( not included ). Specification
    Model: V9
    Type: TV Box
    System: Android 7.1
    Processor: Amlogic S912
    CPU: ARM Cortex-A53
    Core: 2.0GHz,Octa Core
    GPU: ARM Mali-T820MP3
    RAM: 3G RAM
    RAM Type: DDR3
    ROM: 32G ROM
    Max. Extended Capacity: 32G
    Decoder Format: H.264,H.265,HD MPEG4
    Video format: 1080P,4K x 2K,ISO
    Audio format: WMA
    Photo Format: BMP,GIF,JPEG,JPG,PNG
    5G WiFi: Yes
    Bluetooth: Bluetooth4.0
    Power Supply: Charge Adapter
    Interface: AV,DC 5V,HDMI,Optical,RJ45,TF card
    HDMI Version: 2.0
    System Bit: 64Bit
    Power Type: External Power Adapter Mode
    Product weight: 0.0900 kg
    Package weight: 0.3730 kg
    Product size (L x W x H): 9.00 x 9.00 x 1.60 cm / 3.54 x 3.54 x 0.63 inches
    Package size (L x W x H): 18.20 x 12.20 x 5.20 cm / 7.17 x 4.8 x 2.05 inches
    Package Contents: 1 x Vasteyu V9 S912 TV Box, 1 x Power Adapter, 1 x USB Cable, 1 x Remote Control, 1 x English User Manual
    Gearbest
    https://www.gearbest.com/tv-box/pp_687490.htmlToday we can have a look at the Vasteyu V9 S912 TV Box - 3GB RAM + 32GB RAM
    We can check if good things come in small packages
    Android 7.1, Amlogic S912, ARM Cortex-A53 2.0GHz,Octa Core ARM Mali-T820MP3 3G RAM ~ DDR3 ~ 32G ROM
    The Box
    What's in the box
    Rear Ports
    Side Ports
    Underside
    Underside PCB
    Top Side and a rather sizable heatsink
    The Bits that make it Happen
    Looks Ok, clear of a small part of the bench and see what happens
    More to come
      On with the testing...
      Switch on excellent with this little Unit,
      Get that (maybe fuzzy or warm) feel when you turn on and start to do things while setting it up
      This has a good feeling about it so far
      Google login setup, update easy...WiFi good.
      Installed testing apps etc easy no nasties and into it.
      Nice unit, temps ok in the 60~70c when pushed idle low 40C
      Ram speed Ok as you will see, seen better but ok.
      Performance for a stock standard off the shelf pretty good I feel
      Android 7. Upper and Lower Bars, root and no SU..More soon.
        So away we go with System information and UI
        UI
        System Info
        DRM Info
        Upper and Lower bars with Root
        Ram and Storage Truth
        WiFi Connection
        YT 1080P
        Geekbench CPU and Compute
        Full Details > http://browser.geekbench.com/v4/cpu/3859097
        CPU-Z
        Vellamo
        3Dmark ok, seen better
        A1SD
        So as seen not to bad..for a stock of the shelf.
        Netflix played OK looks good as YT...
        So a quick overview look at
        Thanks to Gearbest for the the opportunity to Show and Tell
          Were y can find the firmware for this box i just contacted the seller and they dont have it. And y search everywere and nothing. Please y need the firmware or another firmware from other box that work on this one. Thanks. Sorry for my bad english!!!
            Please make a dump of the firmware y brick mine and y need the firmware.
              STOCK FIRMWARE PLEASEEEEEEEEEEEE!!!!! TKS
                Firmware for this box please y bricked mine!!!!!!
                  Hi, it looks like there is no firmware available for this device. Mine got bricked after a month which I find ridiculous. I wonder if I could use the firmware of the "R-TV BOX Pro" (see link below). I created a bootable SD disk with this firmware by following that how-to https://www.cnx-software.com/2016/11...ogic-tv-boxes/
                  Is it worth a try? I am desperate. I mean it's bricked, it can't get worse anyway, right?
                    This firmware is untested by me but if you still need it this might help.
                    link: https://pan.baidu.com/s/1Sf7afz0cQKDs9KMx6dt3rg
                    Password for link:oz3k
                      So did it work with the firm ware? I have the same issue...
