Found KERNEL(s) with Lag Fix that works for our CX-919
Originally posted by nbhnohome View Posthttp://www.freaktab.com/showthread.p...2-IV-or-UG007B
I've tested the 720p no OC kernel with Finless 4.2.2 1.4 and it works great. No more choppy 1080p video playback.
nbhnohome,
Thanks for the link. How hot did your CX-919 get when streaming 1080P video with this kernel?
smithmal
Originally posted by nbhnohome View PostI've stripped my stick since Day 1 so the stick does not heat up too much ( around 82-86 degree/ Room Temp is 75).
[ATTACH=CONFIG]2923[/ATTACH]
What kind of temps were you getting before the strip down? What are the cons of removing the outer casing. Is there a guide somewhere that provides a step-by-step on how to do this properly?
smithmal
Originally posted by smithmal View PostWhat kind of temps were you getting pore the strip down? What are the cons of removing the outer casing. Is there a guide somewhere that provides a step-by-step on how to do this properly?
smithmal
To enable the fan, you can either connect it to different power source OR/ splice off extra micro usb cable, connect it to the fan cable ( use red and white wires) and connect to FIRMWARE Flashing port on the stick ( you can use other 5V Power Supply with higher current ouput but STOCK one works fine for me.)
For the antenna, i cut it off from the case and glue it to Full-Size USB port (the plastic side since it's easier to superglue to plastic than to metal but be careful, dont let glue run down to the inside (superglue gel is much easier to control than its liquid cousin)Last edited by nbhnohome; 06 August 2013, 19:54.
Originally posted by nbhnohome View PostThe stick heats up to about 120-140 degree with case on and stock heatsink (garbage) and kept rebooting itself so i opened it up, remove stock heatsink(heat it up with your hair dryer but dont overdo it then twist it off). I used heatsink + fan from my old computer graphic card (if you can't remove it by force, dip it in alcohol or nail polish remover (acetone or non acetone base) for 5 or 10 minutes. I use thermal compound + super glue to attach new heatsink onto rk3188. If the new heatsink is too big, you can trim it down or just let it sit over 2 memory modules that is next to rk3188 (with some thermal compound on them so both the memory modules physically transfer heat to the heatsink (leaving air gap between them is bad).
nbhnohome,
Thanks for the response. That's some hardcore modding there!
smithmal
Mind you that looks like alot of weight to cantilever on the HDMI port ..... not worried about screwing the HDMI connection?
Now i have finless 4.2.2 1.4 without the kernel with lag fix.
Originally posted by Chachotio View PostI have the tronsmart and i dont know why but first time it worked ok, but today i have problems with the wifi, it doesnt connect and when it does, system reboots (something strange if that it doesnt connect automatically but if i touch the antenna with the finger start to connect, but when it does it reboot as i said). I reflashed but the same happens.
Originally posted by nbhnohome View PostYou might want to underclock CPU to 1.4 Ghz instead of 1.6 Ghz. One of my friend has the rebooting issue with his CX-919 and doing this does the trick.
I have the finless 4.2.2 1.4 with it kernels and it works great though
There are currently 3366 users online. 1 members and 3365 guests.
