M8 BOX No Recovery
When you were using the USB burning tools, did the flashing process complete successfully as far as the burning tool was concerned?
Are you sure that the firmware(s) that you have used are compatible with your box?
The likes of the M8 spawned a lot of clones, some of which didn't have the hardware inside the box that the vendor said it did and so could have meant you flashing firmware, which you might have quite reasonably assumed was correct but didn't match up to the hardware.
At this point it may be worth opening up the box and tale some detailed pictures of the board and all it's identifiable components.
Even if all is as it expected, one of the last resort solutions may be to short a couple of pins on the board, so you may end up opening the box anyway to resolve the issue.
Have you tried this method?
https://chinagadgetsreviews.blogspot.co.uk/2015/04/how-to-unbrick-any-amlogic-devices.html
From what I have read, the pins that would require shorting are 28 and 29,
There are currently 2797 users online. 0 members and 2797 guests.
