A5X MAX Android 8.1. RK3328 4K 4GB/323GB TV Box WIFI Bluetooth LAN HDR VP9 USB3.0
    Specification
    General Brand: A5X
    Model: A5X MAX
    Quantity: 1 Piece
    Hardware & OS CPU: RK3328 Quad-Core 64bit Cortex-A53
    GPU: Dual-Core Mali-450
    OS: Android Oreo
    RAM: 4GB DDRIII
    ROM: EMMC 32GB
    Communication WiFi: 2.4G WIFI, 802.11 b/g/n
    LAN: 100M
    Bluetooth: Bluetooth
    Media Decoder format: 4K VP9 Video decoder, H.265/H.264 video decoder
    1080P other video decoders (VC-1, MPEG-1/2/4, VP6/8)
    Media format: Avi/Ts/Vob/Mkv/Mov/ISO/wmv/asf/flv/dat/mpg/mpeg
    Music format: MP3/WMA/AAC/WAV/OGG/DDP/HD/FLAC/APE
    Support Photo format: HD JPEG/BMP/GIF/PNG/TIFF
    HDR: HDR10 and HLG modes
    HDD file system: FAT16/FAT32/NTFS
    Support Subtitle: SRT/SMI/SUB/SSA/IDX+USB
    High Definition video output: 4K (4096x2160 pixel )
    3D: 3D video formats
    Interface USB host: 1*High speed USB 3.0 3*USB 2.0,
    Card reader: SD cards
    LAN: Ethernet:10/100 standard RJ-45
    HDMI: HDMI 2.0a for 4k@60Hz
    SPDIF:Support
    AV: Support
    DC IN
    Power 5V/2A
    Package Contents Power adaptor,HDMI cable,user manual ,remote
    Gearbest
    Today we can have a look at the A5X MAX Android 8.1 RK3328 4K 4GB/32GB TV Box WIFI Bluetooth LAN HDR VP9 USB3.0
    The Box
    What's in the Box
    Ports
    Under
    Upper
    Plastic Casing
    Spec on the box not to sure if it's a Warning, or an Advertising stunt
      Hi @trebor what are your impressions of this box performance wise? Looks like it will be going on sale on aliexpress for 11:11!
      • trebor
        trebor commented
        Editing a comment
        Don't know.
        Failed on first boot (dead) was waiting for a replacement.
      Received my box from aliexpress yesterday so far really happy with it plays 10bit h265 flawlessly. Comes with Kodi and several useful apps already installed which I appreciated also came with a remote which I wasn't expecting. Best part is in only cost me $36 US what a bargain!
        The wifi on this is disgusting! I was thinking of buying a wifi adaptor like this to improve things.
        But how would I configure it would it just be plug and play or will I have to change settings on android somehow?
        Anyone?
          I am aware from other units that type of PCB built in Antenna they are not the best.....did you try moving channels up or down in your router may help.
          Not sure how you would re-configure that thing as Android is more Plug and Pray
          Look forward to your findings
            Ahh ok thanks man. Router settings are good as every other device gets plenty of bars for example my phone and laptop get a good 4-5 bars each and they are basically next to it. it's just the A5X Max that struggles it barely picks up wifi and constantly disconnects. It's a shame because besides that it's a great box. I'll keep doing some research and let you guys know how I go.
              Hello everyone
              I have been an A5X MAX 4GB for months and tried to put the firmware of the A5X Max + as an update, and once installed perfectly with its apk plugs but I noticed that the Ethernet and Wifi connections did not work, returning again to install the original firmware of the device .
              The problem is that I do not have the Supersu, and when I install it in the original firmware, it does not start.
              Any solution ?
              Thank you.
                Previously I started a review with the 4/16GB Android 7 version.
                Now we get to see the 4/32GB version with Oreo 8...
                All the same as previous images above, PCB Ram remove
                Difference being the 32GB eMMC this unit is using a Toshiba eMMC I believe
                Same WiFichip and PCB Antenna,
                I do hope it's an improvement over the last 3328 with Oreo...more to come
                And I see the same warning as about also
                Click image for larger version  Name:	Clipboard01.png Views:	1 Size:	179.6 KB ID:	732095
                Gearbest
                  I hope that soon finds an update to Android 8.1!
                    A5X MAX Android 8.1 TV Box RK3328 4GB RAM + 32GB ROM 2.4G WIFI BT4.0 Support HDR 4K
                    On with a bit of an overview of what we have and don't.
                    There is no Root access, or upper and lower Bars.
                    A Typical startup wizard as seen many times. (not shown)
                    The Ui I feel is snappy and overall ok so far.
                    Set up Google account updates and installed apps all good.
                    Running 1080 UI none of this upped 720 stuff, looking good and better than some already tested.
                    Let's have a look see at what we have:
                    UI installed Apps
                    System Information
                    More Info looking a little different
                    Maybe a few extra items in Dev Mode
                    Ram and Storage Truth
                    Sd Card Test and Information
                    DRM Info
                    CPU-Z
                    Geekbench 4 CPU
                    More > http://browser.geekbench.com/v4/cpu/8731129
                    Geekbenck Compute
                    Finally who has the Milk
                    Gearbest
                      A5X MAX 4GB/32GB RK3328 4K TV BOX FIRMWARE UPDATE 20180613
                      as Found
                      source. blog.geekbuying
                        Thank you Trebor. Has anyone updated from version 7.1 to 8.1?
                          8.1 has been a bit of an problem for the Mi Box and others
                          Being New to be expected, if it's working ok for now dont fix it I say
                          But in saying that you will never know if you don't have a go.
