docooler m9s pro problem
hello all, i have a docooler m9s when i plug it in am not getting any power at all.. I tried using a different plug i know that working same problem not getting any light at all.. downloaded the usb burn tool an trying to install a new firmware to see if it would fix the problem.. the burn tool is seeing the box bonnected but when i start it keeps failing at 2% is there something am doing wrong or the box just really bad.. or could i be trying to install the wrong firmware for it
Tags: None
Hi shadydawg ,
first did you ever flashed a Amilogic Device before ??? what "Error Message" came up ???
what Firrmware did you download , was it really a Firmware for your Device ???
some Boxes can be started with a A to A USB Cable and the right USB Plug ,
ever tried ??? (booting with Powersupply over the USB port)
maybe this can help :
http://freaktab.com/forum/tv-player-...ting-need-help
but first ask there and report .
nice Day
gefattern
nice Day
gefattern
There are currently 3473 users online. 0 members and 3473 guests.
