HIGOLE BOX1 Smart Mini PC Intel BayTrail-T CR Z8350 1.44 - 1.92GHz Windows 10 OS BT 4.0
    Specification
    Brand: HIGOLE
    Model: BOX1
    Type: Mini PC
    System: Windows 10
    Processor: Intel BayTrail-T CR Z8350
    CPU: Intel BayTrail-T CR Z8350
    Core: Quad Core
    GPU: Intel Gen 8-LP
    RAM: 2G RAM
    RAM Type: DDR3
    ROM: 32G ROM
    Max. Extended Capacity: 64G
    Decoder Format: HD MPEG4
    Video format: 1080P,AVS,H.263,H.264,MJPEG,MPEG1,MPEG2,MPEG4,RMVB ,VC-1,WMV
    Audio format: AAC,AC-3,APE,FLAC,MP3,OGG,WAV,WMA
    Photo Format: BMP,GIF,JPG,PNG
    Support 5.1 Surround Sound Output: No
    5G WiFi: No
    Bluetooth: Bluetooth4.0
    Power Supply: Charge Adapter
    Interface: AV,DC Power Port,Ethernet,HDMI,TF card,USB3.0
    Language: English,Multi-language
    DVD Support: No
    HDMI Version: 1.4
    Other Functions: Others
    External Subtitle Supported: No
    HDMI Function: HDCP
    Power Consumption.: 5V 3A
    RJ45 Port Speed: 100M
    System Bit: 32Bit
    WiFi Chip: RTL8723BS
    Power Type: External Power Adapter Mode
    Product weight: 0.5700 kg
    Package weight: 0.9750 kg
    Product size (L x W x H): 13.60 x 12.70 x 3.70 cm / 5.35 x 5 x 1.46 inches
    Package size (L x W x H): 20.20 x 14.30 x 4.75 cm / 7.95 x 5.63 x 1.87 inches
    Package Contents: 1 x Mini PC, 1 x Power Adapter, 1 x English User Manual
    Gearbest
    Now we can have a look at the Intel BayTrail-T CR Z8350 1.44 - 1.92GHz Windows 10 2/32GB, 2.4GHz WiFI, Dual Lan Ports@ 10/100 BT 4.0
    Supplied with a 5vdc 3amp power pack
    Thanks to Gearbest
    Tough looking little unit lets see what it's all about
    The Box, No sleeve, has that Industrial Grade look.
    What's In the Box, all metal construction.
    The Look Around
    Under
    Top
    Of with the Base, plenty of vents.
    Base and Top inside view, RTC Battery
    Top Side PCB
    The Bits that make it happen
    ​Port extension
    A Basic performance Unit, 10/100 lan, 2.4GHZ WiFi, I see in the Cmos a Android reference I think this is more a tablet PC in Box and some creative interfacing.
    but if you have a small job to be done, a dedicated PC might be handy.
    Going along OK, have just updated Windows 10 to the latest, will have a look later at some performance and info etc.
    More to Come
      Let's have a quick around and what we have and a bit of a test on the HIGOLE BOX1 Smart Mini PC Intel BayTrail-T CR Z8350 1.44 - 1.92GHz Windows 10 OS BT 4.0
      As mention it's ok for what it has and can do the Basic stuff as required, no Beast but maybe handy for that set Job.
      Windows 10 32 Bit installed, 2/32GB bit low but most tests show it can handle it well.
      WiFi Ethernet speeds OK here to do most.
      WIndows all up and runing
      Device manager
      Not much room
      Working out ok.
      HwInfo
      Ethernet Speed ok
      WiFI
      Ram Speed/benchmark
      Bit of a Thrashing, the Start.
      The Finish, no Graph just numbers, slow increase to 75c and sat there.
      GPU
      CPU
      Another Cashe Memory Benchmark
      CPU-Z much of teh same
      Plenty of these type of Units about all have there Pros and Cons, depends on what you need the unit for
      Small office, something for the Shed, or work..
      A summary for the readers or the group:
      Code:
      Version                                           AIDA64 v5.92.4300
          Benchmark Module                                  4.3.759-x32
          Homepage                                          http://www.aida64.com/
          Report Type                                       Quick Report [ TRIAL VERSION ]
          Computer                                          B_BRICK (baby brick)
          Generator                                         B2
          Operating System                                  Microsoft Windows 10 Home 10.0.14393.1770 (Win10 RS1)
          Date                                              2017-11-05
          Time                                              04:07
      --------[ Summary ]-----------------------------------------------------------------------------------------------------
          Computer:
            Computer Type                                     ACPI x86-based PC
            OS Service Pack                                   [ TRIAL VERSION ]
            Internet Explorer                                 11.1770.14393.0
            Edge                                              38.14393.0.0
            DirectX                                           DirectX 12.0
            Computer Name                                     B_BRICK (baby brick)
            User Name                                         B2
            Logon Domain                                      [ TRIAL VERSION ]
            Date / Time                                       2017-11-05 / 04:07
          Motherboard:
            CPU Type                                          QuadCore Intel Atom x5-Z8350, 1680 MHz (21 x 80)
            Motherboard Name                                  AMI Corporation Cherry Trail CR
            Motherboard Chipset                               Intel Cherry Trail
            System Memory                                     [ TRIAL VERSION ]
            BIOS Type                                         AMI (09/01/2017)
            Communication Port                                ???? (COM1)
          Display:
            Video Adapter                                     Intel(R) HD Graphics  (1 GB)
            Monitor                                           Generic PnP Monitor  (12001)
            Monitor                                           Intel AVStream Camera
            Monitor                                           Sony TV  (220116843009)
          Storage:
            Storage Controller                                Microsoft Storage Spaces Controller
            Storage Controller                                SD Storage Class Controller
            Disk Drive                                        Toshiba 032GE4  (29 GB)
            SMART Hard Disks Status                           Unknown
          Partitions:
            C: (NTFS)                                         [ TRIAL VERSION ]
            Total Size                                        [ TRIAL VERSION ]
          Input:
            Keyboard                                          HID Keyboard Device
            Mouse                                             HID-compliant mouse
          Network:
            Primary IP Address                                [ TRIAL VERSION ]
            Primary MAC Address                               00-60-6E-C2-65-86
            Network Adapter                                   DM9621A USB To Fast Ethernet Adapter(KMDF)
            Network Adapter                                   DM9621A USB To Fast Ethernet Adapter(KMDF)  (192. [ TRIAL VERSION ])
            Network Adapter                                   Microsoft Wi-Fi Direct Virtual Adapter
            Network Adapter                                   Realtek RTL8723BS Wireless LAN 802.11n SDIO Network Adapter
          Peripherals:
            USB3 Controller                                   Intel Cherry Trail SoC - USB 3.0 xHCI Controller [D-1]
            USB Device                                        DM9621A USB To Fast Ethernet Adapter(KMDF) #3
            USB Device                                        Generic USB Hub
            USB Device                                        Logitech USB Input Device
            USB Device                                        USB Composite Device
            USB Device                                        USB Input Device
            Battery                                           Microsoft AC Adapter
          DMI:
            DMI BIOS Vendor                                   American Megatrends Inc.
            DMI BIOS Version                                  CHIPHD
            DMI System Manufacturer                           Default string
            DMI System Product                                Default string
            DMI System Version                                Default string
            DMI System Serial Number                          [ TRIAL VERSION ]
            DMI System UUID                                   [ TRIAL VERSION ]
            DMI Motherboard Manufacturer                      AMI Corporation
            DMI Motherboard Product                           Cherry Trail CR
            DMI Motherboard Version                           Default string
            DMI Motherboard Serial Number                     [ TRIAL VERSION ]
            DMI Chassis Manufacturer                          Default string
            DMI Chassis Version                               Default string
            DMI Chassis Serial Number                         [ TRIAL VERSION ]
            DMI Chassis Asset Tag                             [ TRIAL VERSION ]
            DMI Chassis Type                                  Desktop Case
