firmware docooler m9s pro
Originally posted by shadydawg View Postok i am having trouble atm.. i unzip the file an got the recovery imgae but when i try to load it in the usb burning tool.. I get parse burning image fail.. could it be a bad firmware?
Originally posted by shadydawg View PostNothing same thing i have it spelled like this "recovery.image"
i am trying to see if this will work on the box
http://chinagadgetsreviews.com/downl...ro-tv-box.html
Maybe something like docooler.img
The only way that I know of would be to use TWRP recovery but whether there is one that would work correctly with your box I don't know.
This thread gives you an idea, but talks of flashing TWRP, which I would be wary of unless you know that it will work for your box.
http://www.tvboxforum.com/printthread.php?tid=826
But it does allow you to boot into TWRP from an SD card.
Whether you can use TWRP at this point to backup the machine to a flash drive I'm not sure as I've never attempted it but there is no harm in trying to see if it will boot and backup all the partitions.
There is a lot of discussion regarding TWRP on Freaktab, so worth researching to see what may be possible.
This would be a good starting point.
http://freaktab.com/forum/tv-player-support/amlogic-based-tv-players/16228-twrp-for-amlogic-devices
Originally posted by shadydawg View PostI have another box with me now that the same as the one am working on now.. is there any way i can save the firmware from that box an load it to this one?
Have u manage to find a custom rom ,or a firmware thats works on this Tv box,??I have exactly the same model and is worst tv box ever ...work verry slow for an S905xbox i have over 30 Tvboxexes but this one is the single one thats runs so slow many bugs and nonresposive...and i canon find any firmware or custom rom thats work on this piece of crap not even the original one ....
There are currently 3581 users online. 1 members and 3580 guests.
