T95zplus 3gb Ram 32gb Rom Playstore dont work
    After a update the Playstore dont work anymore, when i click on the main page on the Playstore icon it ever says its not installed. is there anything i can do to fix it? Click image for larger version
    Some possible suggestions in here?
    https://www.androidpit.com/google-play-not-working
    Also, if you go to the app drawer and run it from there instead, does it load then?
      Over the apk manager it works from time to time to open it . But not ever
      When i got the folder --- root explorer -> system->app->google store--- is nothing inside this folder..shouldnt be there a apk?
        I think it is under /data/app/com.android.vending-1
          when i follow your way i found it..can install it ..open it..it works ....but still cnt open over the main screen, it still says its not installed .. the folder is namend here com.android.vending-2
            Sounds like the launcher is not pointing to the right place then.
              and what to do now?
                Report it to the vendor you purchased it from so that they can talk to the manufacturer.
                Then I guess either use a different launcher (or see if somebody will modify the existing one).
                Or run the apk directly (if there is an option to add apps to the launcher draw, you may be able to do it that way).
                One other thought is perhaps to create a vending-1 folder and copy the contents of the original into it (ensuring that all the same permissions are set) and see if that is what the launcher is trying to point to. Or rename the current folder.
                Or even install the latest Play store and see if that works (probably best only as a last resort though in case it screws something up).
