V88 plus
Here's the lasted firmware you can install https://mega.nz/#!j19WEDTA!XSCGw-El8...wBQX5-rzOPN8s4, best one in my opinion. I haven't overclocked mine but considering this box has root its probably possible to manipulate the kernel with applications like this one https://play.google.com/store/apps/d...rillsCPU&hl=en.
Originally posted by anthony96 View PostHere's the lasted firmware you can install https://mega.nz/#!j19WEDTA!XSCGw-El8...wBQX5-rzOPN8s4, best one in my opinion. I haven't overclocked mine but considering this box has root its probably possible to manipulate the kernel with applications like this one https://play.google.com/store/apps/d...rillsCPU&hl=en.
How do I know the WiFi card model of my v88 Plus 2GB box? Wanted a ROM with root but already experienced more than 10 ROMS and none that have root catch WiFi.
Thks
Originally posted by didocas View Post
Thks
you must look inside , to be 100% sure , if you know what to to , it is enough to post the
ChipName & Nr. or a good nearby Pic. of the PCB . greetings / gefattern .
Here's the correct firmware for MX4V with RTL8189 board https://yadi.sk/d/S5wgXCgM3L9jN8, I still have yet to find Android 6 firmware for this board, seems like Scishion no longer uses 8189 card for the V88 plus since April 2017.
Originally posted by anthony96 View PostHere's the correct firmware for MX4V with RTL8189 board https://yadi.sk/d/S5wgXCgM3L9jN8, I still have yet to find Android 6 firmware for this board, seems like Scishion no longer uses 8189 card for the V88 plus since April 2017.
There are currently 2089 users online. 0 members and 2089 guests.
