Got an MK808b plus, that I'm trying to connect to my PC. I tried connecting my mk808 on a few different PC with different windows system on them and I always get the following message (See attachment). MTP USB Device FAILED. Is there a driver that i can download or something? Getting very frustrated.
Thank you gefattern. Installed the "Rockchip Drivers 4.4" and still getting the same message. When you say MTP Mode in settings. Can you elaborate on that? not sure about what to do.
Downloaded and installed your burner. Then plugged the MK808b plus. Then windows is trying to install the proper driver. Getting the following message…''Installing device driver'' and then back to that same message ''Device driver was not successfully installed''. MTP Usb device failed.
I’ve attached a picture of the MK808b plus setting if it can help. I just want to restart everything or make it factory setting.
