Tanix TX8 Max - Android 7.1.2 New stock firmware for BETA testing
    Hi, I would like to share a BETA version firmware for Tanix TX8 Max. Based on Android 7.1.2
    BETA FIRMWARE FOR AP6255 Module
    Click image for larger version  Name:	Tanix-Box-TX8-Max-BETA-Test.jpg Views:	1 Size:	50.7 KB ID:	663105
    A new TANIX launcher will be added to the official release, it is not included now because it is under development right now.
    Download firmware here: Tanix TX8 Max BETA Firmware Android 7.1.2 for AP6255
    BETA FIRMWARE FOR 9377 Module
    A new TANIX launcher has been added to the official release, it is included now but under testing.
    Download firmware here: Tanix TX8 Max BETA Firmware Android 7.1.2 for 9377
    Cheers
    Android TV Box direct from China. English & Español
    SIgn up to dowload...Hmmm
      It is just a mail list. Download links are sent by email.
      The point is: When a new firmware is available for TX8 Max the system will send you a notification with the link to download the next version.
      By this way you are always informed without check the site.
      Unsubscribe is as easy as press a button... in case you do not want to be informed.
      I think it is a good idea.
        Yes good idea.
        Just could have been mentioned in the first post sign up to download.
        They all start out as just mailing list
          Ok, next time I will explain this better on the first post.
          By the way, if someone have a try with the firmware and find problems, can post here and I will report directly to Tanix engineers.
          The new launcher has not been included because it is not finished yet.
            Hi, I edited the first post and added BETA firmware for 9377 WiFi/BT module
            This time (9377 module) an also beta version of the new Tanix launcher has been included too.
            This launcher is going to be included in both stock firmware
              Hmmm downloaded it and not that launcher in the 9377 also no playstore in the firmware. But runs ok let me know when you update the firmware with new launcher and the playstore addon. Id remove the kodi addons they are crap anyways. Just my thoughts. Firmware kinda useless the way it is now. But like the look of your new launcher ill try once its ready. Custom boot animation would also brle Nice. Seeing mbox one is typical. Be créative brand logo and make nice boot show off Tanix lol....
              Mulity user missing as well.
              Task bar on or off with out swip up or down.
              Rbg fix
              Few other things but runs cool so far.
              Best Regards
                I'm testing on my one firmware 6255, on this beta version, i cannot find chplay, also can not install from usb, kodi also cannot install, wifi can not connect with 5ghz like can't search any of 5ghz wifi signal.
                  Hopefully it supports kodi 17 auto frame rate switch
                    Firmware as it is pretty useless we wait for updated one now.
                      Any update on new firmware?
                        There was an update from their site 2 days ago.
                        Got an email
                          I am on same mailing nota for 9377
                            will the latest firmware update fix the issue in Kodi where the videos play too dark?
                              ap_6255 version, No playstore...Mbox only UI
                              Upper and Lower task bars ok.
                              This is Pre Beta more like Alpha...
                              Let's make this happen fellas
                              For those that want to have a look inside etc
