SCISHION V88 Mini III TV Box RK3328- 2/8GB 2.4 WiFi Fast Lan.
    Today we get to have a closer look at the V88 Mini V III RK3328 2/8gb 2.4 WiFi and Fast Lan
    Click image for larger versionName:	1.jpgViews:	1Size:	31.7 KBID:	663253Click image for larger versionName:	2.jpgViews:	1Size:	20.7 KBID:	663252Click image for larger versionName:	6.jpgViews:	1Size:	33.0 KBID:	663254
    Click image for larger versionName:	3.jpgViews:	1Size:	26.5 KBID:	663249Click image for larger versionName:	4.jpgViews:	1Size:	29.9 KBID:	663250Click image for larger versionName:	5.jpgViews:	1Size:	27.9 KBID:	663251
    Model: V88 Mini III
    Type: TV Box
    System: Android 7.1
    CPU: RK3328
    Core: 1.5GHz
    GPU: Mali-450MP2
    RAM: 2G
    RAM Type: DDR3
    ROM: 8G
    Max. Extended Capacity: TF card up to 32GB (not included)
    Decoder Format: H.264,H.265,HD MPEG1/2/4
    Video format: 4K,H.264,H.265,MPEG1,MPEG2,MPEG4,VC-1,VP8,VP9
    Audio format: AAC,FLAC,MP3,OGG,RM,WMA
    Photo Format: JPEG,JPG,PNG
    5G WiFi: No
    WIFI: 802.11b/g/n
    Bluetooth: Unsupport
    Power Supply: Charge Adapter
    Interface: AV,DC 5V,Ethernet,HDMI,SPDIF,TF card,USB2.0,USB3.0
    HDMI Version: 2.0
    RJ45 Port Speed: 10 / 100Mbps
    System Bit: 64Bit
    Power Type: External Power Adapter Mode
    Power Adapter Output: 5V 2A
    Remote Controller Battery: 2 x 1.5V AAA battery ( not included )
    Product weight: 0.0950 kg
    Package weight: 0.3620 kg
    Product size (L x W x H): 10.00 x 10.00 x 1.70 cm / 3.94 x 3.94 x 0.67 inches
    Package size (L x W x H): 17.50 x 13.50 x 6.40 cm / 6.89 x 5.31 x 2.52 inches
    Package Contents: 1 x TV Box, 1 x HDMI Cable, 1 x Remote Controller, 1 x Charger, 1 x English User Manual
    Bit of a look what is on the Inside
    Click image for larger versionName:	8b.jpgViews:	1Size:	46.9 KBID:	663259
    Click for Lager image
    Click image for larger version  Name:	9.jpg Views:	1 Size:	45.1 KB ID:	663262
    Not much to see, same Ram as Top Side
    Closer look at Ports
    All help together with Quality Plastic Base and Lid:
    Click image for larger version  Name:	7.jpg Views:	1 Size:	22.2 KB ID:	663270
    A bit of an Overview of the Bits involved with the SCISHION V88 Mini III TV Box RK3328
    Get it all back together and run a few test and see what it can do.
    Gearbest
      Now for an overview of OS, UI and Performance
      Switched on all good no fires, and connection to wifi OK bit sluggish,
      Connection to Google ok login...
      Problems started, many apps not compatible (aptoide is your friend)
      Appears slow and sluggish and with a quick temp check we are running in the Hi 60c at idle ..and peeking 95c+ when doing stuff.
      So I dare say the firmware at this stage is Not 100%
      Running Android 7.1.2, unit root and no SU installed.
      A few quick tests and a look see then we might wait for a firmware update/fix
      You will notice Temp display middle Centre upper of some screens
      Click on them they should go bigger.
      Click image for larger version  Name:	a2.png Views:	1 Size:	240.7 KB ID:	663309Click image for larger version  Name:	a4.png Views:	1 Size:	255.2 KB ID:	663308Click image for larger version  Name:	a3.png Views:	1 Size:	52.2 KB ID:	663307Click image for larger versionName:	b1.pngViews:	1Size:	91.4 KBID:	663316 Click image for larger versionName:	a11.pngViews:	1Size:	21.5 KBID:	663310Click image for larger version  Name:	a9.png Views:	1 Size:	62.5 KB ID:	663312Click image for larger version  Name:	a10.png Views:	1 Size:	67.5 KB ID:	663313Click image for larger version  Name:	a8.png Views:	1 Size:	71.5 KB ID:	663311
      Click image for larger version  Name:	a21.png Views:	1 Size:	80.0 KB ID:	663319Click image for larger version  Name:	a12.png Views:	1 Size:	85.4 KB ID:	663318Click image for larger version  Name:	a13.png Views:	2 Size:	60.2 KB ID:	663320 Click image for larger version  Name:	a6.png Views:	1 Size:	61.9 KB ID:	663322Click image for larger version  Name:	a7.png Views:	1 Size:	45.0 KB ID:	663321Click image for larger version  Name:	a20.png Views:	1 Size:	238.1 KB ID:	663323
      Click image for larger version  Name:	a16.png Views:	1 Size:	202.9 KB ID:	663324
      Will leave it there...
      For now...Bit warm...few issues at present
      Hope for a fix soon.
        Man thats HOT.. lol damn...
          I was gonna buy this...looks like it would make a better cup warmer....
            hi friends,
            we ask the supplier to provide the new firmware as soon as possible.
            if I forget to reply to this thread, pls PM me or check our CS Thread
            thank you for your supports.
            Gearbest
            #1
            Gearbest TV Box & Mini PC Page
            #2 Flash Deals Flash Deals
            #3Coupons Coupons, Coupons and More Coupons
              can someone provide me the link to the original firmware? My box stucks (mea culpa) on boot logo ...
              Thank you
                Hi uliveto ,
                best you ask the guy from gearbest again , maybe he can give u a link to the actual Rom ???
                Where did you bought it ??? , ask the Seller .
                good luck
                gefattern
                  Hi uliveto ,
                  good luck
                  gefattern
                  Hi, yes I also contacted gearbest but just trying to see if someone else own such a file...
                  Thank you
                    Hi uliveto ,
                    already ask the others , if they know , i of they post it , but not sure if something is available .
                    write you later (please dont flash unknown Roms)
                    gefattern
                      Nothing available as yet for this rom,
                      Also have asked and on the list.
                        Thank you guys for your support, I was brave abd tried other roms, but no one is compatible with this device. I'll wait and pray ;-) and of course this is the last time that I buy a device without a downloadable rom... Have a good Sunday ...
                          Hi uliveto ,
                          that is a good decision , next Time buy a better supported Box , like Nagrace , Ugoos , and other companys , but i think
                          there must be somewhere a working Rom for your Box , but until now not found .
                          good luck / gefattern
                            I'm interested in using this device as a nas server with multiple external hdds. As for the overheating if I were to modify the cooling even without the box would there be a difference or the firmware is so fkd that nothing would make a difference?
                              There is a newer version of the firmware
                              Working better,
                              But still running 64bit, and 1080p so that adds some grief to this device.
