TX8 MAX TV Box S912 Android 7 3/32GB Dual WiFi Gig Lan BT4
    Model: TX8 MAX
    System: Android 7.1
    Processor: Amlogic S912
    CPU: Amlogic S912,Cortex A53
    Core: 2.0GHz
    GPU: ARM Mali-T820MP3
    RAM: 3G RAM
    RAM Type: DDR4
    ROM: 32GB
    Max. Extended Capacity: 32G[/TD]
    Gearbest
    Today is the day we can have a closer look at the
    Thanks to Gearbest for the opportunity to show and tell.
    White clean looking unit, if you're into white that is.
    White remote easy to find and different look good to see.
    Currently there is new Beta Software under test I am yet to load will see how this fires up and decide,
    So lets have a look
    The Box
    What's in the Box
    Ports, TF card on side
    Facing Down side
    Click for Larger Image
    Facing Up side
    The Lid and good ventilation on either side of lid excellent.
    The Base
    Looking pretty good well made Samsung Chips, AP6255 WiFi,
    Good to see, as small as it is Thermal Pad between heatsink and Weight Block
    Myself will cover with a bigger piece if required,
    All Fired up running Android 6.0.1 at present, date 20170321 to old.
    Beta Android 7.1.2 it will be...
    More to come...
