Another M8S TV Box issue
    HI Guys, could you please help with another TV box issue, I've managed to muck up upgrading Android to the stage where I only get the LED light up RED then change to BLUE with a black screen, Could someone please start me at the beginning with identifying the M8S box I have and the image file required etc Thanks in advance...
ID:	663900Click image for larger version
    Hi Olley ,
    can you reach Recovery ???
    greetings
    gefattern
      HI, As above, I just get a black screen, if I,m holding the reset button with a toothpick my screen loops receiving a signal then not receiving a signal, I can connect using the USB Burning Tool but when writing the Image file there is ALWAYS an error. Thats why I need to start at the beginning to ensure have the correct procedure and software.
        Hi olley , so it is a S812 Device , is this correct ??? U need USB Burning Tool for AML Devices , Drivers are
        coming with the Installation .
        Here is a LInk how to flash :
        and here we can go further with this Thread and looking for the right FW , there are some Links :
        so lets discuss there further over your Problem and look what we can do for you . What WifiChip do u use ??
        I shall move this Threads to this Site , so we dont build many new Threads with same Problems , please confirm .
        But first i must know if it is S812 .
        greetings
        gefattern
          Hi gefattern, This is the specs from where the TV Box was purchased
          Chipset Amlogic S812 Quad core Cortex A9r4 2GHz
          GPU Octa-core Mali-450MP GPU @ 600MHz
          ROM 8GB NAND FLASH
          RAM 2GB DDR3
          Power Supply Specifications
          Power Supply DC 5V 2A
          Power Indicator (LED) Power ON :blue;
          Main Features
          OS Android 4.4
          Bluetooth Bluetooth V4.0
          3D Hardward 3D graphics acceleration
          Support Decoder format HD MPEG1/2/4,H.265, HD AVC/VC-1,RM/RMVB,Xvid/DivX3/4/5/6 ,RealVideo8/9/10
          Support Media format Avi/Rm/Rmvb/Ts/Vob/Mkv/Mov/ISO/wmv/asf/flv/dat/mpg/mpeg
          Support Music format MP3/WMA/AAC/WAV/OGG/AC3/DDP/TrueHD/DTS/DTS/HD/FLAC/APE
          Support Photo format HD JPEG/BMP/GIF/PNG/TIFF
          USB host 2High speed USB 2.0,support USB DISK and USB HDD
          Card reader SD/SDHC/MMC cards
          HDD file system FAT16/FAT32/NTFS
          Support Subtitle SRT/SMI/SUB/SSA/IDX+USB
          High Definition video output SD/HD max.1920x1080 pixel
          OSD type of languages English/French/German/Spanish/Italian/ etc multilateral languages
          LAN Ethernet:10/100M, standard RJ-45
          Wireless Support 802.11 a/b/g/n Dual Band Wi-Fi(2.4GHz/5GHz)
          Mouse/ Keyboard Support mouse and keyboard via USB;Support 2.4GHz wireless mouse and keyboard via 2.4GHz USB dongle
          HDMI HDMI 1.4b up to 4K2K
          AV&YUV Support
          3G Support
            I tried the image file from Enybox (20150523 EM8S KoDi 14.2) but when I opened the file in USB Burning tool I got an error,
              I think that the parse error normally means that the image file is corrupt.
              Try downloading it again.
                HI bluesmanuk, I have tried a lot of image files, only a couple have loaded without any problem, but they still would not burn to 100%
                  Try a newer version of the burning tool.
                  I have packaged up a variety of them here.
                  https://www.dropbox.com/s/hlu6kddbi4f5kd2/AMLogic%20Burning%20Tools.zip?dl=0
                    Hi to both ,
                    maybe it helps , newer Tool , new Download , otherwise we must search for another Rom / Solution .
                    Did you try the FW from Post 6 of the Link ???
                    good luck
                    gefattern
                      Hi check this one out to.
                      Cheers
                      Kevin
                        Thanks guys, I have been away for a week, but will try the above mentioned links...
                        I will let you know if I put a hammer through it!!
                          i have the same problem, android 4,2, couldnt run some apps so i flashed firmware and now can only get right light!!
