Here is my newest work with the most recent Tronsmart rom that has bluetooth keyboard support. It's got proper root now, init.d should be all good, and a few new ui changes. I'm running it currently and so far so good. In the package I have also included kernels that will get you over 17,300 in antutu. The default ones get around 15,300 or so. I have not updated the screenshot. These tests were done with the 720p kernel. I really like this rom now and think I may switch to it permanently until a newer decent stock one comes out for me to mod.
8/7/13 updated download to jjhmod.v1.4 version
-new kernel. 800mhz ram clockings. Higher speed, same heat - shouldn't need any cooling mods with the stock kernel.
-changed how USB OTG works. You may have to untick the "connect to pc" box one time and reboot but after that it'll take whatever it has plugged into it automatically.
-added some kernel tweaks - support for a few random devices.
-tweaked voltages for cpu and ram.
So anyways, the Updated Download Link MK908-android.4.2.2.jjhmod.v1.4
I would ditch all other versions of the jjhmod rom and move up to this one.
Here's a link to the kernels included with the v1.4 package if you would like to try them with other roms.
Kernel Download Link
and just for giggles, here are the faster kernels included in the above package.
Speedy Kernel Download Link (just changed default to no-op and ondemand)
As always my deepest appreciation to the crew here at Freaktab for all the support, snippets of code, and so on. Your work is apparent in my work.
Here are some screenshots!
These results are with the default 720p kernel.
