I've heard about you well on the web
My android box has been bricked after adding a repository in code.
bho! However it is now a brick medium.
I tried the usb tool and the procedure with the micro sd card failed both
Maybe i could use the method with trwp but i do not know the procedure
However the main is a CZ-S43-V3.1 (DDR4) 3G / 32 GB amlogic S912 64 bit
I attach front and back photos (obscured mac)
I read several posts, I tried to refill with various firmware by spiking various options. I always get error at 2% or at most 4% on U-boot download.
This is the statistical error
0x10105002 13
0x31520902 5
0x355f0902 1
0x11620902 4
0x10303004 2
I used at least four types of usb cables and three different operating systems (thinking of a possible software hardware driver incompatibility)
The image files used are the following:
aml_s912_q9377-CSA93Q3 (3 + 32_kodi17.0) -20170104_mac.img
aml_7.1_s912_q9377-S912-XGO_mac-20170619.img
aml_7.1_s912_q9377-H96PROPLUS_912_mac-20170602.img
aml_s912_q9377-H96ProPlus(3+32)_mac-20170308.img
GT1_311M0.img
TX8MAX-ddr792-20170321.img
Maybe these image files are not suitable for this device?
To break this nail there is an alternative solution?
I noticed six pitches near the s912 (yellow circle)
Can you access the terminal using a serial box? Or a j-tag?
Is there a software to access it and a detailed procedure?
Confidently look at your star
