For the video, this is the same problem as the other ROM RK3188.
WIFI = OK
Bluetooth = OK ( headphones audio)
LAN = OK
After 10 min, bug bloc, reboot, ...
tested ROM "MINIX NEO X7" in la Tronsmart T428 + kernel_t428_phja_20130802_vsf_ocl_720 ( phjanderson )
very smooth
Score antutu = 18194 ( 1800 MHz X4 )
WIFI = OK
LAN = OK
Video, streaming, adobe flash, 720p and 1080p, video network in 720p, ...
( video, a little better, the ROM "T428 HFW 1.1.2 VF" ), this is just my impression.
- the best of the best ROM actualy is "T428 HFW 1.1.2 VF" -
( information for developers )
After 2 hour of use :
No bug, with kernel phjanderson, works perfectly
the Tronsmart T428, is not hot( normal), for me, the less hot in ( 1800 MHz X4 ) , currently
PS: This ROM is really excellent, to make a custom ROM ( in Tronsmart T428 ), in my opinion
