Remote.conf required! R-TV S10 DDR4
Originally posted by Wenkie View PostThanks, I did everything as you explained but the remote still doesn't work :-( then I have to stick with my k400.. The only thing is that I can't turn it on.. Have to unplug and plug it back in
BTW you can try this method but it requires root.
install terminal emulator from play store
type these command in terminal
su
(grant su permission if asked)
then
dmesg -c
then
press all buttton in remote in sequence you can remember like power>home>dpad up> dpad left> so on
now type
dmesg | grep "code is 0x"
it will show multiple message in this format wrong custom code is 0xAABBCCCC ( BB = button code CCCC = factory code)
for e.g
remote: wrong custom code is 0x7e817f80 ( here 0x81 will be your first pressed button code and 0x7f800001 will be your factory code)
remote: wrong custom code is 0x7c837f80
so on
each line is in sequence you pressed the button for e.g 1st line showing code for power button 2nd for home and so on
now open remote.conf ( copy it to sd or usb storage from superceleron rom i.e from system/etc you may not able to edit in original place) file in any text editor
first edit factory code is this format 0xCCCC0001 ( CCCC is last 4 digit of your remote code like mentioned above)
now below you can see many hex code which is button code followed by random 1 to 3 digit numbers these numbers represent type of key(you can see these codes in keylayout/Vendor_0001_Product_0001.kl file for e.g
key_begin
0x45 125 #MENU
0x42 1 #BACK/EXIT
0x0d 97 #ENTER/OK
0x10 105 #LEFT
0x0b 103 #UP
0x0e 108 #DOWN
0x11 106 #RIGHT
0x18 115 #VOL+
0x17 114 #VOL-
0x4d 116 #Power
0x1a 102 #home
key_end
edit these hex code with your button hex code accordingly and save remote.conf now replace this new remote.conf file to system/etc folder reboot box and check.
I try this method because stock rom of damn r10 did not work after while,i try vorke rom-it works fantastic,i try all files published here but something wrong..keylayot files vendor0001 is empty, most of keys works only down key and back key don't.I try other method with dmesg, but doesn't return me key for down key and back key.Please someone to make instruction step by step,without twrp ,if it is possible
There are currently 1890 users online. 3 members and 1887 guests.
