Xnano X5 Realtek RTD1295 TV Box - 2G RAM + 16G ROM
    Model: X5
    Type: TV Box
    System: Android 6.0
    Processor: Realtek RTD1295
    CPU: ARM Cortex-A53
    Core: Quad Core
    GPU: ARM Mali-T820MP3
    RAM: 2G RAM
    RAM Type: DDR4
    ROM: 16G ROM
    Max. Extended Capacity: 64G
    TV Box Features: 5.1 Surround Sound Output
    Decoder Format: H.263,H.264,H.265,HD MPEG4
    Video format: 4K,H.263,H.264,H.265,VP9
    Audio format: AAC,FLAC,MP3,RM,WMA
    Photo Format: BMP,GIF,JPEG,PNG,TIFF
    Support 5.1 Surround Sound Output: Yes
    Bluetooth: Bluetooth4.0
    Power Supply: Charge Adapter
    Antenna: Yes
    Camera: Without
    Language: English,French,Russian,Simplified Chinese,Spanish
    DVD Support: No
    HDMI Version: 2.0
    Other Functions: 3D Games,DLNA,ISO Files,Miracast
    External Subtitle Supported: Yes
    HDMI Function: CEC
    Power Consumption.: 15W
    RJ45 Port Speed: 10 / 100 / 1000Mbps
    System Bit: 64Bit
    WiFi Chip: AP6221A
    Power Type: External Power Adapter Mode
    Product weight: 0.4000 kg
    Package weight: 0.6430 kg
    Product size (L x W x H): 12.30 x 8.50 x 1.90 cm / 4.84 x 3.35 x 0.75 inches
    Package size (L x W x H): 16.10 x 11.60 x 7.50 cm / 6.34 x 4.57 x 2.95 inches
    Package Contents: 1 x TV Box, 1 x HD Cable, 1 x IR Remote, 1 x English User Manual, 1 x Power Adapter
    Gearbest
    Today we can have a close look at the Xnano X5 Realtek RTD1295 TV Box - 2G RAM + 16G ROM
    There has been a few of these RTD 1295 devices arrive of late starting way Back from Zidoo with the X9S
    and then a few more, like all media players with time they do start to improve and as more people get
    on board they can end up being a very useful Unit.
    So lets have a look
    The Box
    What's in the Box, All Metal Case
    One Big OK button on that remote
    Front Display and Ports and more Ports
    Under side
    Topside
    Click for larger image
    Casing
      A few Tests, Information and a look around the UI etc
      Power on 12v 2 Amp power pack all good
      Easy connect WiFi 5ghz
      Easy Connect Google and Login etc.
      Update a couple of apps, load a few no problems there.
      Running Android 6., no root currently,
      UI simple Looks ok, annoying (to me) taskbar slides out from the Left side, Different as you will see.
      HDMI in and Out same as Beenlink and I guess many others.
      Openwrt settings much the same as seen in other RTD1295 units
      Ok a few Images and a quick look around
      Launcher
      Installed Apps
      Version
      Side Navigation Bar, hope to find a setting to contain it.
      HDMI in/record
      A floating View image app
      CEC Functions
      More Settings to get Openwrt settings
      Another launcher feature I found Menu Button on remote lets you Customise add/remove icons from Home screen
      Further fiddling you can make a reale mess of it if you wish Crazy Launcher.
        Now to a bit of testing......
        Youtube ok 1080p
        Netflix app installed not HD but very watchable
        Overall not too bad for this little unit with lots of Extras to be found...Box is cool not running Hot, Small compact and neat design.
        much the same as other RTD1295, But Metal Box, Clock, and the Bizarre launcher put it were you like Icons won me.
        OTA update all good at this stage
        DRM, I not a DRM app also installed have to suss that one out Later
        Wifi Speed and ethernet good
        Ram and Storage truth
        Vellamo
        Antutu not to bad
        Cpu-Z
        A1SD-Bench
          Just a quick overview of the Xnano X5 Realtek RTD1295 TV Box - 2G RAM + 16G ROM
          I went to attach the SSD just realised at the time No sata/power cable supplied, thought that unusual.
          Unit has KD player (Kodi 17.3) installed and a swag of stuff included
          Being a RTD device the inbuilt player player does a good job and plays most well.
          Openwrt seems in order I don't have a need to use myself some may, so read up on it to see if it is for you.
          Good WiFi and Ether connection, as mentioned good looking unit ,metal casing and a crazy launcher..
          Performance OK much as other Units in this Range of RTD.
          Thanks Gearbest for the opportunity to Show and tell.
            I have problem with recording from TV with HDMI IN. I use 1920 x 1080 resolution but there is no problem with picture. When I try clip after recording I notice that picture is good but there is no voice. Is there any settings to resolve that problem, any settings for HDMI IN sound?
              Bought one of these unused but s/hand on and it has turned up with a 5v psu I have 2 others the same model and they came with a 12v psu.
              Wandering if any one knows if it would run on the 5v one ??
