Many thks to gearbest for sending me the device to play
Must of the changes where under the hood
I REALLY RECOMMEND ADDING A HEATSINK TO THE CPU!!!
READ THE BUGS SECTION FOR UNNECESSARY QUESTIONS!!!!
UPDATE ARE - SCV1 (IMG) -> SCV3 (OTA) - IF YOU ARE ON ANY SCVV1*/SCV2 IT WILL UPDATE JUST FINE TO THIS ONE!
Changelog V3 Cumulative OTA:
- Fixed passthrough in Kodi 17, SPMC 17, FTMC 17, maybe others... (DTS, DTS-HD etc...)
- Updated Youtube APP to 2.01.04
- Fixed UI crashes
- Some UI changes:
- - organized the icons on status bar dropdown.
- - fixed and screenshot function on navigation bar
- - removed led control from navigation bar
- - Fixed and added back power button in navigation bar
- Some video optimizations ( tested in two different's online ISP's TV and both give HD streams just fine )
- Other little stuff...
- Same as V1
- And more i guess....
Changelog V2 OTA:
- Fixed Some launchers not working (Nova Launcher...)
- Fixed gamepads keys
- Enabled Multiusers ( Max 3 )
- Enabled round icons, if the apps supports it.
- Other little stuff... crash fixes etc...
- THE 1º BOOT AFTER THIS UPDATE TAKE A BIT LONGER, AFTER THAT IT GOES TO NORMAL AGAIN, SO WAIT FOR THE BOOT TO FINISH!
- In youtube app when you search if it ask to access you microphone deny it or else it will crash.
Changelog V1A OTA:
- Removed the hard locked launcher, so you guys can now choose your own launcher.
- Added lighthome launcher, so now theirs 2 on the rom.
- Fixed a nasty(my fault lol) AMCODEC bug in FTMC Krypton(to be rls) and SPMC krypton(is NOT the 16.8rc1..) and possible others.
- Same as V1
- I bet there is more...
Changelog V1:
- 55% based on stock
- Big optimization, is really fast now and i mean fast... you will see it!
- Navigation should be smooth as silk and fast.
- New Boot Logo, many thks to danielelek90 for the great work
- Custom Wetek WebOs launcher (Many thks to wetek for let me use it)
- - Menu Button is king on this launcher, its used to add remove icons on the main screen, also to remove widgets.
- - Long press on the default icons on desktop you can change them to other apps (White Logos...)
- - Long press on the icons you add to the deskop and you can rearrange them.
- - Bing Pic of the day background.
- Netflix, youtube, playstore...etc... fully working
- 4k Youtube support.
- initd.d support.
- PS3/PS4 gamepad support ( only with cable... )
- Added Xbox360/XboxOne gamepad support ( cable, wireless and Bluetooth )
- Added Dragonrise USB HID game controllers.
- Added upper and lower bars ( status bar and navigation bar )
- Added Status and Navigation's bar's auto hide!
- Removed supersu app ( See bugs section )
- Wifi range and connection speed should be a little better.
- Permissions fixed. ( lots... )
- Many KL's added.
- Fixed AMCODEC playback.
- Some audio mods.
- FTMC Build 30
- Added Android TV screensaver ( default 5 min )
- Added a setupwizard.
- Optimized some animation stuff!
- And a lot of other stuff that i dont remember now! ( ye ye i know i need to make notes... )
- Removed superuser app to avoid bootloop's if anyone by mistake updates the su binary.... i will fix that in a next build!
- No TWRP for now, im having some weird issues with it... so that is going to take more time... sorry no Magisk install of course because of that
- Possible a lot more!
Want to buy me a beer?
Download SCV3 Cumulative OTA:
- DOWNLOAD HERE OTA SCV3 Beta for Khadas Vim 2
- MD5: 9D094C1B0432156293CA92ACFB630BB3
- DOWNLOAD HERE SCV1 Beta for Khadas Vim 2
- MD5: 4282A1DAB00B3F7F7BF452E8D9CED70F
Install instructions:
- Use usb burning tool.... the img
- Use recovery the OTA..
Where to buy:
1º BOOT MAY TAKE +/- 6 MINUTES!
THIS ROM DELETES ALL YOUR DATA SO DO A BACKUP!
USE AT YOUR OWN RISK!
Enjoy it!
