MK908 dead while flashing. Looking for Dr. Frankenstein...
    Hi there,
    Anyone here who can help me reanimating my MK908?
    It died while i tried to upgrade to Finless1.5.
    When plugging in, the FW Utility finds the stick and i (sometimes!) can clear the memory.
    Then it counts onwards to the end and tells me everything is ok.
    But when trying to flash the ROM it throws an error.
    Here are the logfiles from the ROM_Flash_Tool_137.exe i used:
    Erase (Error)
    Code:
    21:04:58 000    INFO:Start to erase NAND
    21:04:58 000    INFO:Start to lower format
    21:05:03 015    ERROR:LowerFormatDevice-->RKU_TestUnitReady failed,subCode(0xfd),Errcode(-2)
    21:05:09 046    ERROR:LowerFormatDevice-->RKU_TestUnitReady failed,subCode(0xfd),Errcode(-2)
    21:05:15 078    ERROR:LowerFormatDevice-->RKU_TestUnitReady failed,subCode(0xfd),Errcode(-2)
    21:05:16 078    ERROR:Lower format failed
    21:05:21 109    ERROR:EraseIDB-->GetFlashInfo failed
    21:05:21 109    ERROR:Erasing IDB failed
    Flash (Error)
    Code:
    21:05:59 156    Loader Device Path(\\?\USB#VID_2207&PID_310B#5&428A151&0&1#{a5dcbf10-6530-11d2-901f-00c04fb951ed}),ThreadID=2368
    21:05:59 156    INFO:Start to test device
    21:05:59 156    INFO:Start to run
    21:06:04 187    ERROR:TestUnitReady failed,Errcode(-2)
    21:06:10 218    ERROR:TestUnitReady failed,Errcode(-2)
    21:06:16 234    ERROR:TestUnitReady failed,Errcode(-2)
    21:06:17 234    ERROR:Test device failed
    21:06:17 234    INFO:LoaderThread failed
    21:06:17 234    ERROR:Run failed
    Erase
    Code:
    21:07:46 890    INFO:Start to erase NAND
    21:07:46 890    INFO:Start to lower format
    21:07:55 906    INFO:Lower format OK
    21:07:55 906    INFO:Erasing IDB OK
    Flash (Error)
    Code:
    21:09:23 812    Loader Device Path(\\?\USB#VID_2207&PID_310B#5&428A151&0&1#{a5dcbf10-6530-11d2-901f-00c04fb951ed}),ThreadID=2264
    21:09:23 812    INFO:Start to test device
    21:09:23 812    INFO:Start to run
    21:09:23 828    INFO:Test device OK
    21:09:23 828    INFO:Start to download IDB
    21:09:23 828    Flash Chip Information:
    21:09:23 828    NO        SIZE(MB)    Manufacturer
    21:09:23 828    ----------------------------------------------
    21:09:23 828    0        8192MB    MICRON
    21:09:23 828    INFO:BuildFlashStateMap start
    21:09:23 828    ERROR:BuildNFBlockStateMap-->TestBadBlock failed,ErrCode(-3)
    21:09:23 828    ERROR:BuildFlashStateMap failed
    21:09:23 828    Error:Download IDB failed
    21:09:23 828    INFO:LoaderThread failed
    21:09:23 828    ERROR:Run failed
    try using the factory rom
    current devices(rockchip sucks)
    Hardkernel ODROID C1 running android kitkat
    Hardkernel ODROID XU3-L Running Linux/openelec (primary media server)
    rPi model B+ running nothing ... bricked
      SO i tried with, what i think, is the factory ROM.
      No success.
      Tried the RK Batch Tool too. But it says in its logfile:
      Code:
      17:34:36 265    Rockchip Batch Tool v1.6.8.1 start run
      17:35:05 031    **********Upgrade Start Total<1>**********
      17:35:05 031    <Layer 10-1> Test Device Start
      17:35:05 031    <Layer 10-1> Test Device Success
      17:35:05 031    <Layer 10-1> Check Chip Start
      17:35:05 031    <Layer 10-1> Check Chip Success
      17:35:05 031    <Layer 10-1> Get FlashInfo Start
      17:35:05 031    <LAYER 10-1> INFO:FlashInfo: 0 0 0 1 0 10 10 28 1F 4 1
      17:35:05 031    <Layer 10-1> Get FlashInfo Success
      17:35:05 031    <Layer 10-1> Prepare IDB Start
      17:35:05 031    <LAYER 10-1> INFO:CS(1)        (8192MB)        (MICRON)
      17:35:05 031    Error:RKU_Read-->ReadFile failed,bRet=0,err=31,size=64,read=0
      17:35:05 234    Error:RKU_ClearBuffer-->ReadFile failed,bRet=0,err=31,size=512,read=0
      17:35:05 234    <LAYER 10-1> ERROR:BuildBlockStateMap-->RKU_TestBadBlock failed,RetCode(-4)
      17:35:05 234    <LAYER 10-1> ERROR:PrepareIDB-->BuildBlockStateMap failed
      17:35:05 234    <Layer 10-1> Prepare IDB Fail
      17:35:05 234    **********Upgrade Done Success<0> Fail<1> Time<203>ms**********
      There is no different behaviour when using any other ROM.
      I always got this
      'Error: Downloading IDB failed'
      message.
      Looked like something couldn't withstand the heat inside the stick, as i would have modified this at next.
      For flashing i tried
      the 'ROM_Flash_Tool_137.exe' coming with Finless 1.5,
      the 'RKBatchTool.exe'. came with Finless too and
      the 'RKAndroidTool.exe' (V1.37) wich i got from 'MK908-android.4.2.2.jjhmod.v1.3'.
      The jjhmod seems like the one that was at first on the stick.
        Re: MK908 dead while flashing. Looking for Dr. Frankenstein...
        Try a different usb wire, a different usb port (it must be a 2.0 port), try other pc too if you can.
        leolas
        My devices:
        Gearbest.com)
          you can try and short the pins on the NAND
          tut
          Auf YouTube findest du die angesagtesten Videos und Tracks. Außerdem kannst du eigene Inhalte hochladen und mit Freunden oder gleich der ganzen Welt teilen.
          Edit depending on the PCB you may need to short the pins directly on the chip
            I suggest short the nand pins like the last solution. If you try to flash your device in mask mode with bad wire, usb connection or bad drivers you will got a Perma brick.
            leolas
            My devices:
            Gearbest.com)
              Anyone wants to give me a kick?
              It was this stupid USB cable!
              Runs now like a charm.
              Thank you very much to all.
