Tanix T8 Max Latest Firmware Review
Originally posted by scooter2014 View PostBecause it worked on alf I'd say super Celeron has the most fixes by far... but for stock Rom one of the best I'e seen so far.
I have a TX8 Max White box and the ROM's launcher is not looking anything like that except for a dumb ugly MBOX startup flash screen. I can't replace the launcher with another 3rd party one. Is the latest firmware version for this model a ATV stock or a basic Android tablet/phone stock?
Actually I preferred the original Android 6.0 startup flash screen than the ugly MBOX one in their latest BETA firmware.
Bad review on Tanix part. They can't even release a stable Android Nougat ROM for the TX8 MAX and they're already moving on to the TX9 and other models.
So have they officially abandoned all development and updates for the TX8 MAX rom?
If so, this will be the last time I'm buying anything TANIX branded from now on.
TX8 Max 3/16 DDR4 7.1.2 ATV rom .img (for use with burning tool). Everything working as expected. https://drive.google.com/file/d/11bo...ew?usp=sharing
Originally posted by bishoplog24 View PostTX8 Max 3/16 DDR4 7.1.2 ATV rom .img (for use with burning tool). Everything working as expected. https://drive.google.com/file/d/11bo...ew?usp=sharing
Originally posted by xtazi View PostHi,
I finally managed to flash the 7.1.2 Beta on my TX8. There is no Play Store and can't manually install it, any suggestions?
Is there any other recommended custom 7.1.2 ROM for TX8?
Elie
One issue I have is with using other launchers (Nova, etc.), they keep crashing, is there a workaround for that?
Thanks in advance.
scooter2014
Hi i want to install Tanix Tx8 Max Firmware in my Mecool M8S Pro L , though the wifi chip is different, If i swap the wifi folder from mecool into tx8 and change the permission, will it work ?
please kindly guide me, this is my model with 3/32gb
Hi, ok i tried Tanix T8 max Img, in my h96 pro plus 3/32gb (9377),its getting bricked, only black screen.tried both the ways with USB Tool and burn card maker with Erase Boot Loader (Not Selected),Means Unchecked, what is the problem any idea? Do i have to install with the Erase Boot loader Ticked Option,I see i have a single 3gb Ram installed, Do the H/W is the problem
for getting brick,
Thanks.
You may only view thumbnails in this gallery. This gallery has 3 photos.3 Photos
Originally posted by tiku View PostHi, ok i tried Tanix T8 max Img, in my h96 pro plus 3/32gb (9377),its getting bricked, only black screen.tried both the ways with USB Tool and burn card maker with Erase Boot Loader (Not Selected),Means Unchecked, what is the problem any idea? Do i have to install with the Erase Boot loader Ticked Option,I see i have a single 3gb Ram installed, Do the H/W is the problem
for getting brick,
Thanks.
YES , the difference in HW , bricked it , please for Future , only flash if you exactly know that
the FW you want to flash , works on your Box , now you must unbrick it , as possible ,
with PC or maybe the SDCard Way works , good luck , greetings / gefattern
Thanks gefattern, but just for my inquisitiveness, superceleron SCV1 BLUE (LPDDR3) PCB Image works perfectly ok in my box, it is also based on Alfawise H/W, then why not Tx8 Max Image?
is there a chance that i am using H96 pro plus Boot Loader so its not working, should i try to patch with Complete Erase option including the Boot loader? so the new image will be with the stock bootloader of tx8 max.
I have to used pin short method both the times in my previous attempt to revive back my box,as there was original boot loader present in the image, but was not being detected on usb tool,
so i am scared if i use erase boot loader option, will i be able to again get it back via Pin Short Method??
Please Kindly Reply.
There are currently 1236 users online. 2 members and 1234 guests.
