Hey Guys,
i love my cheap Minix a lot.
He did a good job with sky go and now i want to watch netflix too.
i installed actually Wasser Fimeware 3.0.6 with Lolipop, but the problem ist i cant watch Netflix with root.
I want to replace Supersu with Magisk to watch Netflix.
But i dont have acces with TWRP 2.7 -2.8.5 for RK 31. to my storage partition.
Hey Guys,
From a fresh 3.0.6 wasser rom ie no superSU (remove superSU from within app if you have it)
1 enable developer mode and turn off root access, reboot
2 download netflix 4.16.1 from e.g. Apkmirror
3 launch netflix, might error 0013 the first time, but then works 100%. A reboot after install and first launch also helps
Well my netflix stopped working after a couple of weeks for no known reason. I don't think magisk hide would work as it needs a minimum kernel version of 3.8
