Where to buy a T95Z PLUS and does it have to be a Sunvell?
    I am wanting to get a T95Z PLUS media player and I stumbled upon this forum. Do the firmware here have to be installed on a Sunvell branded T95Z PLUS or can I get any of the other "Brands" of T95Z PLUS? I would like to get one from Amazon but the only Sunvell brand one shows a EU plug in the pics and are from a seller with no reviews. Also it says Pendoo as the brand in the pics, not Sunvell.
    Yes you can get the box under something othe than the Sunvell name.
    I just Googled T95Z PLUS and found quite a few ads for many vendors, including some of the Chinese based ones that advertise on here.
    So recommend a Google and also use the search function on Freaktab to see what other information, support and custom firmwares there are.
      Hi Diablo2k ,
      impotant to know is , the Boxes must have the same Specs .
      The best to buy a Device that is supported well with CustomRoms
      from here .
      have a nice Day
      gefattern
        I'm about to buy this one because my Dolamee D5 got bricked
        It's worth the money?
          Ok, so I decided to buy my Sunvell t95Z Plus from gearbest.com. Now My only problem is do I get the 2g/16g or the 3g/32g. I can't find any performance comparisons between the 2 but it seems the best Roms are for the 2g/16g so I am leaning towards getting it.
            Yes, sunvell is a manufacturer.
