Many thks to gearbest for sending me the device to play
Thks trebor for the beta test!
READ THE BUGS SECTION FOR UNNECESSARY QUESTIONS!!!!
UPDATE LIKE THIS - SCV1 (IMG) -> SCV3 (OTA) (ALL OTHERS THAT ARE ON OTHER VERSIONS YOU CAN UPDATE JUST FINE )
Changelog V3:
- Fixed passthrough in Kodi 17, SPMC 17, FTMC 17, maybe others... (DTS, DTS-HD etc...)
- Updated Youtube APP to 2.01.04
- Some video optimizations ( tested in two different's online ISP's TV and both give HD streams just fine )
- Other little stuff...
- Same as V1
Changelog V2:
- Fixed fan not starting after reboot!
- Fixed gamepads keys
- Enabled multiuser.
- Other little stuff done... crash fixes etc..
- Same as V1
Changelog V1A:
- Fixed a nasty(my fault lol) AMCODEC bug in FTMC Krypton(to be rls) and SPMC krypton(is NOT the 16.8rc1..) and possible others.
- Turn on the fan by default, in auto sense mode!
- Same as V1
Changelog V1ATV:
- 55% based on stock +/-
- Big optimization, is really fast now and i mean fast... you will see it!
- Navigation should be smooth as silk and fast.
- New Boot Logo, many thks to danielelek90 for the great work
- Netflix, youtube, playstore...etc... fully working
- 4k Youtube support.
- initd.d support.
- PS3/PS4 gamepad support ( only with cable... )
- Added Xbox360/XboxOne gamepad support ( cable, wireless and Bluetooth )
- Added Dragonrise USB HID game controllers.
- Removed Navigation and Status bar just like Real ATV's. ( so dont ask for it )
- Wifi connection speed should be a little better.
- Permissions fixed. ( lots... )
- Many KL's added.
- Fixed AMCODEC playback.
- Some audio mods.
- FTMC Build 30
- Optimized some animation stuff!
- And a lot of other stuff that i dont remember now! ( ye ye i know i need to make notes... )
- And of course all the other ATV mambo jambo LOL
- On setupwizard dont choose tablet to login, choose normal login since the table/etc.. is not working.
- On "More Settings" in settings you will see the white settings, forget it... it wont work it will crash if you press anywhere, real atv dont have that settings.
- Removed superuser app to avoid bootloop's if anyone by mistake updates the su binary....
- No TWRP for now, im having some weird issues with it... so that is going to take more time... sorry no Magisk install of course because of that.
- Possible a lot more!
Want to buy me a beer?
Download SCV3 Cumulative OTA:
- DOWNLOAD HERE Khadas Vim2 OTA SCV3 ATV
- MD5: 61664B3689C02B768929AECD69E545E0
Download SCV1 IMG:
- DOWNLOAD HERE Khadas Vim2 IMG SCV1 ATV
- MD5: C338C6CB9F336D7040EB41539DA71D24
Install instructions:
- Use usb burning tool.... to flash the IMG...
- Use recovery to flash the OTA....
Where to buy:
1º BOOT MAY TAKE +/- 6 MINUTES!
THIS ROM DELETES ALL YOUR DATA SO DO A BACKUP!
USE AT YOUR OWN RISK!
Enjoy it!
