Hello fellow geeks. I’m going straight to the point I have an Android Smart Multimedia Player Model Q7, I believe it is a RK3188 not sure though. I rooted this android box with kingroot (successfully) and root uninstalled some system apps that I found irrelevant. Unfortunately, I think I have uninstalled some severe apps that this device requires to run. Well anyways now that I power it on all I get is a continues android LOGO that never advances to anything. It just stays there with the words ANDROID glowing. I tried to use the recovery options (button) on the bottom of the android box. But when I do all I get is a dead android laying on his back with a red warning triangle appearing on top of the laying android (no other information appears on the screen other than a dead android with a red triangle). No, I did not install a custom recovery like cwm or others. May one of you android intellectuals please link me or give me a step by step on how to fix this Sh*T. In delay, I apologize for the improper grammar. Final note I have a funny feeling that I might have to install or push some sort of firmware / firmware update in order to fix this, my guess. Thank you all in advance.
I’m new to this sorry if I post this I on the wrong place. Please Help with Smart Multimedia Player Model Q7
I’m new to this sorry if I post this I on the wrong place:
Tags: None
Originally posted by chris9119 View PostBump
you must flash your Device new , already done ???
Do you have the Stockrom ??? Flashtool and Drivers ???
If not load them here :
https://m.mediafire.com/folder/2x89d...Rockchip_Tools
take AndroidTool 2.39 and DriverAssistant 4.5 that is all first .
Here you can get the Stockrom :
http://freaktab.com/forum/tv-player-...ection-customs
and
http://chinagadgetsreviews.com/downl...-tv-boxes.html
before you flash be sure that your ox has the same WifiChip , ever opened the Box ??? good luck
gefattern
There are currently 2508 users online. 1 members and 2507 guests.
