Good morning, guys, I can not install the ugoos firmware on my v88 model card (mx4n-v03) I think it is split and bootloader is in version 2.32 I wanted to help you
Ugoos UT6 full in my v88 bootloader 2.32 v88 6.0.1 error firmware check
Good morning, guys, I can not install the ugoos firmware on my v88 model card (mx4n-v03) I think it is split and bootloader is in version 2.32 I wanted to help youYou may only view thumbnails in this gallery. This gallery has 2 photos.2 PhotosTags: None
Originally posted by raulmax3 View PostYes friend, it seems so gefattern
You won't be able to use the Ugoos firmware with a new bootloader since the bootloader and kernel drivers won't match.
You will only be able to use the stock firmware or hope that Ugoos will release a future firmware with a newer bootloader that has support for the RAM, storage or other hardware in your device that is not in the old bootloader.
I saw this problem when i bought a new V88.
V88 with A/V & SPDIF ports orange = bootloader 2.31 (2.32 working fine too)
V88 with A/V & SPDIF ports black = bootloader 2.32 (2.31 not working)
i also bought Docooler R39 (same hardware & v88 rom on it) bootloader 2.32, only 19,75$ with EU plug (29,90 with US, UK or AU)
https://www.tomtop.com/smart-android...p-v2300eu.html
There are currently 2361 users online. 1 members and 2360 guests.
