TWRP for Alfawise H96 PRO+
    Hello, anybody know who i can find the TWRP File for Alfawise H96 PRO+ (3GB,32GB) ?!
    If you have it, please do you have an faq for flash it !? Thanks
    Anyone know any twrp which works with Alfawise H96 PRO+ (3GB,32GB)?
      You can try this TWRP recovery:
      4shared is a perfect place to store your pictures, documents, videos and files, so you can share them with friends, family, and the world. Claim your free 15GB now!
        Originally posted by essko View Post
        This TWRP is ok ?
        I'm looking for TWRP for H96 pro +
          didgerifou
          You can use one from this Rom: http://freaktab.com/forum/tv-player-...roidtv-version
          Just open the .zip of v4a update and there is recovery.img. Checked it this morning and it works.
          It's 3.1.1-0, so newer than from essko's link.
          ALFAWISE H96 Pro+ 3/32 (S32-V6) | 7.1.2 | SCV7A | OC kernel | TWRP 3.1.1-0 | 64GB
            Originally posted by ch3mn3y View Post
            didgerifou
            Thanks.
            Do I need to install it through USB Burning Tool? is that it?
              didgerifou
              ​​​​​​​Nope. Just copy it to SDcard (not sure if it have to be FAT32, but mine is), than turn off Box. Disconnect it from power source, than use something to push the reset button, while pushing, connect the power cord, keep pushing till You see TWRP screen (first will be H96 Pro+ logo, than TWRP). That's it, You are in TWRP.
              Didn't use restore feature yet, but with S32-V6 at least backup worked and format of /cache and /data - was afraid to try /system and restoration).
                didgerifou
                top ! it's good ! it work. thanks.
                  Originally posted by didgerifou View Post
                  it work. thanks.
                  You mean it's booting, or that Backup/Restore is working fine?
                  One more question: Did You open Your Box and know what kind of version are You using? I have v6 Wisdom one unfortunately and there is no working .img for USB Burning Tool...
                    I made a backup of the rom stock with TWRP. I didn't try to restore it.
                    I opened the box, but I don't know what version I have. How can I see it? I know it's a wisdom version (visible in the android parameter)
                    Apparently, there is no custom rom for widsom
                      @didgerifou
                      Between USB ports and SoC heatsink are two lines of text - for me ot's S32-V6 (LPDDR3) | 2017-09-05.
                      Didn't know that it's shown in settings too. Will check later what I have there...
                      ZUK Z2 Pro ✓ᵛᵉʳᶦᶠᶦᵉᵈ
                        didgerifou
                        Ehh. Even here I have something different - no info about kernel build...
                          didgerifou
                          I don't think you're a widsom version... The widsom information is normally only indicated for widsom versions.
                          Isn't your card compatible with superceleron rom?
                          After that, there are so many versions... http://freaktab.com/forum/tv-player-...ponent-changes
                            Mine looks exactly as latest one, but I have S32-V6 not S32-V5 model.
                            Now I just look around to find what OEM made this.
                            About Wisdom I thought when Lakuma restored my TWRP backup on his Wisdom H96 and it works fine...
                            But his has green PCB, mine is blue.
                            I'm just downloading Android TV version. If I brick it, I at least have TWRP backup of working stock
                            EDIT: Nope. Superceleron's AndroidTV Rom gave me bootloader erase error. Seems to be tipical whe trying to flash onto Wisdom powered one.
                              And as a result, the flash Superceleron's AndroidTV Rom was not taken into account? Is the box brick ? No, just, you stayed on stock version...?
