disappointed x7 (wifi)
    If you're mainly using your Android mini PC or STB to stream videos over the web or your local network, Wi-Fi performance is actually more important than
    I'm really... really disappointed in minix
    Reading gkblog....
    Hi, Geeks: Sorry for you wait, i really spent much more time to test this NEO X7 quad core tv box. I have so many hopes like you guys to […]
    That the 'neo x7" comes withe 'ap3660" chipset.. limited to 65mbps
    Just as the 't428" has : look at wifi performence link above.... horrible
    Like going back 10 years....802.11a/b
    Originally posted by mitchell4you View Post
    http://www.cnx-software.com/2013/05/...d-hdmi-sticks/
    Reading gkblog....
    you should look into the real transfer speed instead of just looking at the spec.,
    X7 transfer things fastest amongst all these devices...
      what speedtest.net speeds are you getting
      Is anyone with a fiber broadband getting speedtest.net results of over 35mbps down and 18mbps up?
      that's what the CS918 is doing here...
      cheers, tx
      Mark.
      _________________________________________
      Out: USB audio, HDMI
      In: Logitech K400 keyboards
        Originally posted by fredphoesh View Post
        cheers, tx
        Mark.
        how about you get one and try and if it doesn't do better I pay you the money
          Re: disappointed x7 (wifi)
          What a stupid comment.
          Sent from my GT-I9505 using Tapatalk 2
            in which way you think it's stupid...?
            buying something is stupid...?
            I wanted to test it and tell you but I don't have your particular fibre connection...
            Your own line should be the best comparison environment... it's not stupid at all... apple to apple... experiment... your existing box becomes a control sample in such experiment...
              Buying something after you know you want it is not stupid.
              Suggesting to someone they buy something just to test if one particular feature is working or not IS stupid. It is not helpful and just sounds like you are annoyed at a perfectly reasonable question.
              Surely someone there has a fast broadband connection to test for me?
              tx
              Mark.
              sent from an android device for TV
