Nexbox A95X on Nexus ROM 7.1 TWRP Bricked (Solved)
    Originally posted by SemNizzle View Post
    You also get detection with plug usb cable to box and computer and twrp recovery.img and a dummy update.zip on sdcard. With update&backup.apk you choose the zip file from sdcard and when the box begin to boot you have burning tool connection.
    https://androidtvbox.eu/new-firmware...70913-release/
    I use the Iron Firmware now, its Android 7 Firmware and the Reset Button also work.
    awesome! thanks for sharing!
    will give it a go!
    i will also try the sd card thing you mentioned, i tried it with a normal upgrade and it didn't work
    but getting it to work in usb burn is good enough for me
    update:
    can confirm reset button works in this android 7 build on my a95x a1.
      Hello SemNizzle and others,
      I have also the same box Nexbox A95x 2/16 and I have flashed the U2 + p212_V0321_TVStock-20170730.img firmware. I couldn't connect my box via usb and found this post. I managed to follow your recommendation and flashed the stock firm via putty as you described.
      Following this post I have upgraded to the last Iron 7.1 firmware This firm is very good but I noticed that it isn't rooted. Have you managed to install root or TWRP on this image ? I havn't been able to reboot in TWRP using the normal procedure recovery.img.
      Thanks for your answer.
      k32
        Hey k32
        i also have no TWRP img but I have installed supersu over playstore and i can give rights to apps the only thing I have noticed is If you make an Update on SuperSU and Restart that the box stuck in bootloop. So I use SuperSU without an Update.
        I also hope there comes an TWRP img for IRON Firmware.
          NEW FIRMWARE FOR A95X 1G/8G
            Can you make a rom ATV?
              khanhsac sorry but no i can't
                Please someone help pointing to shorting pin method for Nexbox a95x S905X 2/16g.
                - where and when to short pin when using burning tool method?
                I just bricked it and this model has no reset button.
                Normally I can flash via usb burning tool just by press start and then connect cable.
                But now it won't work anymore because I flash wrong custom rom.
                  Use this video the method is the same for all 905/912 Amlogic Board: https://www.youtube.com/watch?v=fsyS3p5asZs
                    Thanks, I will give it a try as soon as I can. Seem not hard to fix.
                      I just try to short pin like in this video. But didn't work.
                      Is it always the same position (pin 1-2) to short for other boxes? Mine is Nexbox a95x 2/16g model.
                        Short legs 4-5
                          Originally posted by khanhsac View Post
                          Short legs 4-5
                          Thanks a lot. It works now.
                            will give it a go!
                            update:
                            Howardo, how does the Android run on that A95X A1? I could not put my finger on it but that one and the RK3229 aka A95x R1 seem buggy to me on 6.1. Interested in what you have seen with 7 please?
                              Hi guys! First of all, I apologize for my bad English, I'm Italian. I apologize even if I did not show up on the forum, but I could not find the discussion.
                              However, I write because I'm trying everything to unlock my beelink gt1 ultimate, but I can not get over it. You will ask yourself: why do not you write in the beelink discussion? Well, because only here I found people talking about the UART connection. However I tried in vain to flash with usb cable and usb burning tool, with sd and the only solution I see is the UART connection. But even here I have problems: once connected to the PC via USB-ttl 2303, I open putty and after setting everything and pressed "open", nothing appears on the black window! Maybe I have to change the flow control? Or is my box not connected well? I do not know how to do it, please help me!
                              However, my beelink has 6255 chips. Thanks to anyone who will help me!
                                Hello
                                I flashed my box on U2 + p212_V0321_TVStock-20170730.img.
                                everything ran perfect for me except remote.
                                Over the reset button I came then no longer in the recovery menu.
                                the only possibility was via the UPDATE & BACKUP function by selecting update.zip and pressing update. (Recovery.img+update.zip on sdcard)
                                so I could connect again to the computer and also came into the TWRP Recovery menu.
                                The problem what I have now is that I have deleted in the TWRP Recovery menu everything (data, system, etc.) and re-started.
                                Now the box shows only the NEXUS logo. So I can no longer connect to the computer and SD card update does not have any function.
                                Reset Button also have no Function.
                                When I open the Box i see no Pins to short. (see pictures)
                                I hope someone can help me.
                                Resolvel pela porta serial?
