TX8 Max or a T95Z Plus, both have 3GB of RAM
    Looking into getting a new TV Box using the S912 SOC with 3GB of Ram.
    Ideally would like to load up a Android TV rom with PS3 controller support.
    Both are under £60 shipping within the UK, so next day delivery for me.
    The T95Z Plus comes with Android 7.0, TX8 Max Android 6.0.
    Apart from that they are laking any other details.
    how can you load androi tv rom? is there any?
      There are:
      Basically Magendanz makes them for a few devices. I am using one of their Android TV ROMs on a S905X at the moment.
      EDIT#
      Decided to spend £65 on the Mecool M8S Pro S912 3GB 16GB-ROM. When it turns up (within 2 day) I will flash this ROM. Hope I made the right choice with the box.
