MXR PRO RK3328 TV Box Android 7.1 + Quad-core Cortex-A53 + 4K VP9 H.265 + BT4.0 4GB DDR3 32GB
    I found what I looked for, thanks.
      This device looks the same as h96 max h1 and h1 models. Are the software of these devices compatible with each other?
        Look at the Pictures above of the PCB and compare to what you have.....if they look the same should be ok
        Worse case is you may not get wifi or remote..so make sure you have your original firmware to flash back
        just in case
          My device (h96 max colorfull edition h2) motherboard and the information in this shape ...
          You may only view thumbnails in this gallery. This gallery has 5 photos.
            I made the device change ...
              Your WiFi look is different, so May not work 100%
              Click image for larger version  Name:	wifi.png Views:	1 Size:	209.8 KB ID:	712447
              H1 and H2 look not this one
                I still can not find a solution to the green screen problem caused by the rgb problem. It is necessary to edit the kernel files. Even though the device is in sRGB mode, it is not activated.
                  Some early TV not Compatible as you know, cause this problem
                  Try TV in Auto mode sometimes can work ok
                    1920x1080 60p becomes automatic mode. But the problem continues.
                      Sir, please upload orignal firmware Beacuse new firmware not working properly
                      mxr pro 4k rk3328_box-userdebug 7.1.2 nhg47k eng.foxluo.20170816.164003 test keys
                        RK3328-BOX_7.1.2_20180301.1732_MXRPRO i this firmaware wifi and bt no t working please fix it
                        and reply me
                          Originally posted by trebor View Post
                          On testing no Wifi or BT
                          Firmware for this Unit.
                          Not installed as yet or tested
                          https://mega.nz/#!YroC3BzR!PQI-h3Qem...Chp471oY1Y9F8M
                          fine name: RK3328-BOX_7.1.2_20180301.1732_MXRPRO..
                          Gearbest
                          problem still investigating
                          Firmware has right sigs
                          Wifi And Bt not working fix it soon
                            Nice box. Very fast. The only problem I encounter is frequent powering off due to over heating.
                            Are there any fixes for this?
                              Hello i runned firmware for this box.when its opened it has bluetooth share stopped fault.how can i solve it?
                                Just tested the A8 from the MX10
                                Runs OK actually better on this than the intended MX10
                                Remote works, and WiFi works,
                                Different remote and WiFi chip
                                Can't switch BT on this Box, (option is there) guess module not fully present and other Box has no BT
