snakes imito MX1/MX2 based on latest rikomagic rom from 22 july 2013
    ok guys here is the latest android 4.2.2
    i took the latest rikomagic rom from 22 july 2013
    you have now the screenshot app on the taskbar.
    you can activate this app in settings now.
    cwm recovery is also added.
    i changed the default parameter to 4 gig for app space.
    no more special snakekiller themes in the rom.
    its just like the stockrom now.
    because more and more people want the stock look.
    for netflix people use this netflix
    what to do if you flashed the rom.
    first what you see is the cwm page.
    it has many errors like E cant mount blablabla.
    thats normal just press REBOOT NOW.
    when its booted you can choose from 3 launchers .
    choose one and click always.
    now go to SETTINGS/STORAGE.
    mount the internal sd.
    now you see it must be formated.
    format it .
    after format is the internal sd in used.
    after this do a reboot.
    and your stick is ready.
    if you now use the REBOOT app.
    and click to REBOOT RECOVERY.
    you wil see that cwm does not have errors anymore.
    and fully works.
    have fun with the new rom.
    here is the link
    for people who don't like the stock mouse pointer here is another one.
    here is a update zip for cwm.
    this is the new mouse pointer Click image for larger version
    flash this with cwm recovery and you have the new mouse pointer.
    some people ask for flash the whole rom with cwm.
    so i made a cwm flash zip.
    so you must have cwm recovery for using this.
    If you use a stockrom or another rom, you must use the flashtool for flashing my rom instead off the cwm rom zip.
    Once you did that ,you can reflash the rom in the future with the cwm rom zip
    F.Y.I.
    Before you flash the cwm rom ,take first in cwm erase dalvik cache etc.
    Sow that the existing rom is clean like you just flashed it
    Than flash the rom
    here is the link for the cwm rom zip.
    http://sdrv.ms/15SbXg8
    if you love my work please buy a coffee
    <form action="https://www.paypal.com/cgi-bin/webscr" method="post">https://www.paypalobjects.com/en_GB/i/scr/pixel.gif
    </form>
    I installed your Rom today.Have not used the mx2 for months.
    The first install with the CWM method would not boot the Rom it would just booted back to CWM all the time..Tried twice still the same
    So then I installed the Rom with ROM Flash Tool.exe comes with your Rom.
    This time the Rom booted just fine (I like your boot screen) on boot up the nane flash was empty and not mountable so after working out how to format the nane flash as you said in your intro..All was good
    Wifi working good
    installed ES explorer
    Also MX player watch a doco 720p from 500gb usb drive in HW worked fine.(videoplayer_ad__1_7_15a_neon_market) an older version
    Youtube works Good
    Antutu v3.3 =9362 with int-sd
    Won't be installing netflix not into movies.
    Looks like a nice port. Thanks for your work..
      Re: snakes imito MX1/MX2 based on latest rikomagic rom from 22 july 2013
      You must first install the rom with the pc.
      Then in the future if you want reflash the rom than you can use the cwm rom.
      If you come from stock or another rom it wont work.
      Verstuurd van mijn GT-S5660 met Tapatalk
      </form>
        Hello Snakekiller!
        Is Bluetooth working properly with this ROM? Finless 2.0 has well-known bluetooth problems. Has Rikomagic already fixed them?
          Since i use another rom than stock i haven't bt anymore.
          My stick has another bt chip than the rest of us.
          Sent from my GT-S5660 using Tapatalk 2
          </form>
            Sorry? So... bluetooth won't work with this ROM and iMito MX2?
              Yes it works, but not on my type off stick.
              The wifi is the same but not my bt.
              </form>
                The ROM is, unfortunately, worse that Finless ROM 2.0.
                1) Reboot instead of Shut down.
                2) Bluetooth works the same with the same problems as in Finless ROM 2.0
                3) There are strange picture jerks when mouse moves.
                4) Artefacts when video is played. (MX Player, MKV, 720P, HW decoding)
                Nevertheless, snakekiller, thank you very much!
                  Artefacts for video.
                  Strange i and others dont have that on the ug007II
                  </form>
                    Anyway to flash this rom without a OTG port
                    Hey Snake,
                    I broke my otg port and I was wondering if I could flash this rom another way other than otg port? If so How? Thanks Markus
                      If you installed a finless rom then must the cwm installation works.
                      But if not how would you flash the rom back on the normal way
                      Its dangerous on that way if you have a broken otg port
                      </form>
                        Can you tell me how?
                        How do I use the cwm?
                          Just download the cwm rom zip and place it on your sd card
                          Go to cwm recovery and install the zip from external sd card.
                          But i said if it not works for you
                          Then your stick is useless anymore.
                          </form>
                            Is there a Netflix version that works on this rom that dont have subtitles out of sync? The 2.0.2 linked, 2.1.2, and the new 2.4.1 all have subtitles out of sync :-(
                            Or is this common on all roms for the MX1/MX2?
                            -Exlo
                              I dont now , here in belgium no netflix.
                              Sorry
                              Verstuurd van mijn V370 met Tapatalk
                              </form>
